HORSE-USMVMC Posted May 22, 2008 Share #1 Posted May 22, 2008 What Does This Do? It Is Located Under The Right Side Cover In Front Of The Two Relays. Horse Link to comment Share on other sites More sharing options...
Jercoupe Posted May 22, 2008 Share #2 Posted May 22, 2008 If your talking the clear connectors thats your carb heat power and it may come in handy if you ever need to run heated vests and grips. I put a switch inline as per the suggestion of the fourm here and it solved my over amp draw of running everything at once. Link to comment Share on other sites More sharing options...
