EtRider Posted May 18, 2020 Share #1 Posted May 18, 2020 Looking for a rear caliper bracket with the small hole in it to fit over the pin . The bracket I have has the 2 large holes in it. See pictures. Thanks for any help. I thought I would ask here first before going the Ebay route. Link to comment Share on other sites More sharing options...
Prairiehammer Posted May 19, 2020 Share #2 Posted May 19, 2020 Your gold painted bracket is for the 1986-1993 XVZ1300. It appears that you also got the XVZ13 rear caliper with the bracket. The XVZ13 rear caliper will not fit on the XVZ12 caliper bracket, so in addition to needing the XVZ12 caliper bracket, you will also need to get a XVZ12 rear caliper. Link to comment Share on other sites More sharing options...
