ZOEYDOG Posted March 28, 2019 Share #1 Posted March 28, 2019 Any one using the Dunlop D423 Tires Link to comment Share on other sites More sharing options...
ChiefGunner Posted April 2, 2019 Share #2 Posted April 2, 2019 Any one using the Dunlop D423 Tires No, I’ve been able to find online tire prices that my dealership has been willing to honor. Also, when I recently replaced my rear tire, I went with the same Goodyear Excedra Max tire BUT I went with a readily more available and cheaper 60 series tire instead of the stock 55 series. It’s about 3/8” taller across the diameter but the wheel fits without any problems even with a trailer hitch installed. There is ZERO ride or handling difference. The only thing I’ve noticed is that your rpms are slightly lower at speed because the tire covers a bit more ground per rotation. Basically, at the same rpm the stock tire at 85mph is doing 85mph. The taller one at the same rpm will have you doing 87mph. The difference is negligible the slower you go below that point. The tire price was about $80 cheaper too. just thought you should know: Link to comment Share on other sites More sharing options...
Rasa Posted May 25, 2019 Share #3 Posted May 25, 2019 I just order a Dunlop Sportmax D423 200/55R-16 77H Rear Motorcycle for mine. My OE tire has a little of 13k on it and will need to be changed soon. Link to comment Share on other sites More sharing options...
