MoonShine Posted April 4, 2021 Author Share #26 Posted April 4, 2021 Added expanded metal and window screen over the radiator guard for extra protection from road debris and bugs. 1 Link to comment Share on other sites More sharing options...
MoonShine Posted April 10, 2021 Author Share #27 Posted April 10, 2021 (edited) Replaced squeeling speedo with this Trailtech digital unit. Has a magnet gorilla glued to the rotor. Removed the old cable/ housing and capped off the drive at the wheel Edited April 10, 2021 by MoonShine Link to comment Share on other sites More sharing options...
MoonShine Posted April 10, 2021 Author Share #28 Posted April 10, 2021 Center stand mod. I cut around 2 inches off the bottom of the center stand and welded some cross tube on the feet to make a “ride off” stand. It is very easy to pop on the stand (even in flip- flops) and rear wheel is on the ground when on the stand. I carry 2 small chunks of 2x4 to tip the center stand on to lift the rear wheel off the ground or stabilize on soft ground. 1 Link to comment Share on other sites More sharing options...
Marcarl Posted April 11, 2021 Share #29 Posted April 11, 2021 Nice work, especially if it works well. 1 Link to comment Share on other sites More sharing options...
MoonShine Posted April 11, 2021 Author Share #30 Posted April 11, 2021 Added angle braces to package tray to support extra weight in mounted box. Link to comment Share on other sites More sharing options...
MoonShine Posted April 20, 2021 Author Share #31 Posted April 20, 2021 Replaced the rear brake master cylinder and reservoir with a more modern set up. I think it came off a Royal Star Venture from the 2000’s? Link to comment Share on other sites More sharing options...
Marcarl Posted April 21, 2021 Share #32 Posted April 21, 2021 12 hours ago, MoonShine said: Replaced the rear brake master cylinder and reservoir with a more modern set up. I think it came off a Royal Star Venture from the 2000’s? Doesn't look like there is much expansion room in the reservoir, you will need room for the fluid to expand, especially from being so close to the exhaust. If you don't give it room then you can expect brake drag as things warm. Just and observation. Looks handy though.! 1 Link to comment Share on other sites More sharing options...
MoonShine Posted April 22, 2021 Author Share #33 Posted April 22, 2021 Working great for around 2 years and thousands of miles. Thanks, and I will keep my eye on it. Link to comment Share on other sites More sharing options...
