Progressive Spring install ?
cut it out just now, thanks, and my forks have a drain plug in them at the bottom of each fork...
what size did you guys cut the plastic tube for the progressive springs ? and did
you use to same amount of fork oil ?
Spacer Cut is 6.75 inches. Using 15 wiehgt BelRay fork oil. 18 oz
Yeah Don, I think these should be fine since the bike is triked I had
Already ordered them and got them for $52 so I hope they work for my
Bottoming out , otherwise my steering is upright at all times , no leaning.
Edited by Cougar
I'm sure they will be fine. Much better than stock. From what I understand, the problem is that Progressive never actually made a spring for the RSV. The one that they sell was designed for the older Royal Star and it was much lighter. So the spring rate is really not heavy enough for the RSV but probably heavier than the stock springs.
Well, I am DONE !! Its raining so when that lets up I am going for a ride :-)
I don't think I want to ever do that again LOL , seem like it took forever.
I did learn lots tho. I also had to wait on parts as well. so anyways
lets hope the front end stays together ! :-)
Jeff
