Mad Dog Posted May 14, 2016 Share #1 Posted May 14, 2016 frustrated beyond belief. Ready to push bike off lift and let it rust into fine dust, then sweep it up and throw it away.... Anyway, I'm having trouble getting the rear axel all the way in. I can get it to where the shoulder just hits and starts to slide into the swingarm, and then no further. Dont want to use a BFH and ruin the threads on the end. Everything seems fine, just cant get it further. Also, between the brake support thing bar and the wheel itself there is a bearing that has a shoulder on it. So shoulder goes into the tire or into the brake support?? I think it goes to the tire. Thanks again as always! Mike Link to comment Share on other sites More sharing options...
Mad Dog Posted May 14, 2016 Author Share #2 Posted May 14, 2016 frustrated beyond belief. Ready to push bike off lift and let it rust into fine dust, then sweep it up and throw it away.... OK ... the axel is in... guess I just needed to vent and use a hammer... Still checking on the bearing position. TIA Link to comment Share on other sites More sharing options...
bongobobny Posted May 14, 2016 Share #3 Posted May 14, 2016 Yah! Sometimes the pinch bolt area needs to be pried open a little to get the axle to slide in... Link to comment Share on other sites More sharing options...
FuzzyRSTD Posted May 15, 2016 Share #4 Posted May 15, 2016 (edited) #1 - Axle start through frame hole #2 - Through Washer #3 - Through Caliper support bracket #4 - on through and into the frame on opposite side, turning the axle as you go. Once the axle is through both sides, using the allen head socket to turn the axle. Find the sweet spot where that the wheel turns the most free. Mark this spot with a marker and use the pinch bolt center of half's as an alignment. Now bring the axle back out a little more and with a file, file yourself a notch into the axle as a permanent reference to always put the axle back into the same sweet spot. Now, once you get the axle back in; #1 - start the nut and snug it up only #2 - tighten the pinch bolt up on the axle at the sweet spot, 13 Foot pounds. #4 - Now tighten the axle nut to 110 Foot pounds. The caliper bolts tighten to 29 Foot pounds. Important to do this. If you do not have a decent Foot pound torque wrench, and you are going to work on your own bike, you really should get one. Only two tires on two wheels between you and the black top. *There is a complete printable sheet on here somewhere to identify all the correct torque for all the bolts. Edited May 15, 2016 by FuzzyRSTD Link to comment Share on other sites More sharing options...
Du-Rron Posted May 15, 2016 Share #5 Posted May 15, 2016 Should be 29 FT LBS ( FOOT POUNDS)!!! Link to comment Share on other sites More sharing options...
FuzzyRSTD Posted May 15, 2016 Share #6 Posted May 15, 2016 (edited) Should be 29 FT LBS ( FOOT POUNDS)!!! [ATTACH=CONFIG]105330[/ATTACH] Oops, thanks Du-Rron. I was making sure someone was checking. Lol Edited May 15, 2016 by FuzzyRSTD Link to comment Share on other sites More sharing options...
Eck Posted May 15, 2016 Share #7 Posted May 15, 2016 @Mad Dog, I sent you a P-Email with a couple links which include pics and instructions. Link to comment Share on other sites More sharing options...
RedRider Posted May 15, 2016 Share #8 Posted May 15, 2016 One recommendation I have, lightly coat the axle with anti-seize before putting it back together. Makes removing it much easier next time. Don't get it on the threads. RR Link to comment Share on other sites More sharing options...
