Lug Nut Posted May 1, 2016 Share #1 Posted May 1, 2016 Rode my 1998 RSTC home today. Allready picked up/ordered oil, filter, plugs, air filter, fuel filter, final drive fluid, synthetic brake fluid, etc Gonna change out every fluid and filter, flush coolant, flush brake and clutch lines, check pads, maybe rebuild front brake master cylinder. I need a new rider seat and will have stock windshield, leatjer saddle bags and brackets, passenger seat, sissy bar and pad to sell.....gonna make it a solo setup. Link to comment Share on other sites More sharing options...
M61A1MECH Posted May 1, 2016 Share #2 Posted May 1, 2016 OK so that bike does not actually fall into the classification of first or second gen as we refer to them, as those connotations apply only to Ventures. The Royal Star line was started in 1996 after Yamaha dropped the Gen I Venture series a few years before. Those Ventures were first gens and came in the flavors of MKI and MKII. in 1999 Yamaha revived the Venture name with the Royal Star Venture, that is the start of the 2nd Gen, it used the same power plant as the Royal Stars but had some improvements in horsepower, bigger carbs, comfort and smoothness. Yamaha stopped making the standard Royal Stars like yours in 2001 and had only the Venture left in the Royal Star line. In 2005 they re-introduced a Tour Deluxe model, which was a stripped down version of the Venture, same power plant, but no fairing, no trunk and no audio. The Tour Deluxe was dropped in 2010 and the Venture sadly was dropped in 2013. So you have a first generation Royal Star. I doubt there will ever be a second generation Royal Star or third generation Venture, as sad as that is. Because I left Royal Star line after owning 2 for 16 years because Yamaha refused to upgrade and up date the Venture, I am now riding a Goldwing and probably will do until I quit riding, unless Yamaha comes up with something REALLY SPECIAL. I hope Mama Yamaha is reading this. 1 Link to comment Share on other sites More sharing options...
bongobobny Posted May 2, 2016 Share #3 Posted May 2, 2016 Yah!! C. None of the above! As Steve stated, 1st gen and 2nd Gen refer to the Venture only, but it is more akin to the 2nd Gen being a "Star" motorcycle. The 1st generation Venture, both MK1 and MK2 are Yamaha Venture and Venture Royal. The 2nd generation of Venture are part of the Star Line made by Yamaha, Royal Star Ventures... Link to comment Share on other sites More sharing options...
bongobobny Posted May 2, 2016 Share #4 Posted May 2, 2016 BTW Lug Nut, make sure the oil you use is good for a wet clutch!! Either Motorcycle oil, or Diesel engine oil. A lot, if not most automobile oils have friction inhibitors in them which make the clutch slip!! Link to comment Share on other sites More sharing options...
Lug Nut Posted May 5, 2016 Author Share #5 Posted May 5, 2016 Always use motorcycle specific synthetic oil. Currently using Mobil 1 10w-40 4T in both venture and RSTC Link to comment Share on other sites More sharing options...
