capymotiv Posted October 23, 2015 Share #1 Posted October 23, 2015 Been through the post and can't figure out what is going on. I recently lost the right turn signal. Tore down the switch and found the black wire disconnected from the solder post. Resoldered it back on and it works great. However, now the auto cancel is not working. Was working fine before the resolder. Any ideas? Link to comment Share on other sites More sharing options...
Flyinfool Posted October 23, 2015 Share #2 Posted October 23, 2015 Does the cruise control still work? The cruise uses the same sensor as the self canceling. Link to comment Share on other sites More sharing options...
capymotiv Posted October 24, 2015 Author Share #3 Posted October 24, 2015 (edited) Cruise does not work but it quit working long before I had this problem. Canceller worked without cruise working up till I had to repair switch. Tore the switch all down, cleaned everything, resoldered wire, turn signal worked but would not cancel. Guess I need to go through the cruise system? Edited October 24, 2015 by capymotiv Link to comment Share on other sites More sharing options...
