Steering/Tracking
chippego
Hello. I have a 09 RSV with a trike kit. I recently noticed than when going down the road my handlebars seem to be pointed a bit toward the shoulder of the road. Kind of forgot about it and now one side of the tire is scuffing. Haven't hit anything with it..except maybe a pothole.
Any suggestions would be appreciated.
Thanks
A large/deep enough pot-hole could tweak your front wheel in the forks enough to misalign your handlebars slightly. If I were experiencing your issue I would line up the front wheel parallel with the rear ones and secure it so that it couldn't move. Then loosen the triple tree pinch bolts on the forks slightly (not until they are sloppy)and twist the handlebars until they align with the front wheel again. Re-torque the pinch bolts. If the fork tubes are not out of true that should help with your wear problem. Hope this helps!
