JDaniel Posted June 21, 2015 Share #1 Posted June 21, 2015 Had to replace the battery in my 07 Goldwing yesterday. Noticed the engine cranking a lot slower and seemed weak. Had a load test done at Advance Auto. Showed battery needed replaced. New gel battery $103.00 Starts like a champ now. Link to comment Share on other sites More sharing options...
Pam Posted October 28, 2016 Share #2 Posted October 28, 2016 Last few times out I have noticed that the starter didn't didn't have the same zip when I hit the button, and the heated seat and grips are intermittent. Battery tender also seemed to taker a long time to get to full charge even after a good ride. Did a load test on the battery. It started at 12.5 volts and dropped to 8 during the load test, and never regained 12 volts until I hooked the tender back up. I guess come spring I will be battery shopping. Hopefully the intermittent comfort package is related to a poor battery Link to comment Share on other sites More sharing options...
gggGary Posted October 28, 2016 Share #3 Posted October 28, 2016 Was battery full charged by a shore tender/charger when you did the load test? I would be closely checking all battery cables/ ground connections. Get a volt meter on the bike and watch it while you ride for a while. I smell something other than the battery being wrong. But by all means if the battery tests bad replace it. Weak batteries put a lot of load on the rest of the charging system as it tries to charge the unchargable soon causing other problem$. Link to comment Share on other sites More sharing options...
Pam Posted November 8, 2016 Share #4 Posted November 8, 2016 Full charge from a tender when I did the load test, and I have used a multi meter at idle and got 14.5 volts at idle. I will check further to see what is going on with some rpm and check back. Link to comment Share on other sites More sharing options...
Pam Posted November 10, 2016 Share #5 Posted November 10, 2016 I am sitting at 14.75 volts at 3000 rpm, Not sure what the service manual say on this but 14.75 should be sufficient to keep a good battery charged. Problem is my battery is poor, and given the time of year I will wait until spring to change it Link to comment Share on other sites More sharing options...
WildBill1 Posted November 10, 2016 Share #6 Posted November 10, 2016 Cool weather brings out the worst in a weak battery. Link to comment Share on other sites More sharing options...
Brake Pad Posted December 22, 2016 Share #7 Posted December 22, 2016 I just have my battery changed, died while on a ride in Fort Gaines Georgia I too got a Gel Battery 8 year warranty 178.00 Link to comment Share on other sites More sharing options...
