Quick question about water pump removal
I'm getting nervous because of the amount of force I'm having to use to get the water pump off so I thought I should stop and ask someone..
I've taken 5 bolts out of the cover
I've taken 4 remaining bolts out of the housing..
Does the housing just pry off now?? And I should expect the impeller to come off with the housing? I don't have to somehow remove the impeller first do I?
My housing isn't budging.
I see that I've got the plastic impeller so thats gotta go, along with replacing the mechanical seal and what not.
Must have been too embarrassing to share.:doh::confused24:
RandyA
I'm not one to shy away from looking like a fool so others may learn.... The PO seems to have used a particularly tough gasket and sealant combo. I just found a good leverage point and a long enough fulcrum and it popped of..
So alls good.... For now. I'll continue with the engine teardown tomorrow.
