Motorcycle Mike Posted September 9, 2014 Share #1 Posted September 9, 2014 I pulled the trike out of the garage at 04:30 this morning to ride to work. As I'm leaving the neiborhood I realize the only lights hiting the road are my passing lights. The headlight is illuminating the roof tops. No problem I think, I'll just adjust them down with the knob under the fairing. Wrong! Before the light gets anywhere near the road it bottoms out and starts pulling it to the left. No doubt this is caused by rakeing the front end. I'm sure I'm not the first to run into this. What did you do to fix it? Link to comment Share on other sites More sharing options...
kensattitude Posted September 9, 2014 Share #2 Posted September 9, 2014 There are 2 adjustments in there, one with the knob on the left and a 10mm(?) bolt head on the right. I had the same problem the first time I got mine out at night, I could see behind me. Link to comment Share on other sites More sharing options...
bigbob Posted September 9, 2014 Share #3 Posted September 9, 2014 There are 2 adjustments in there, one with the knob on the left and a 10mm(?) bolt head on the right. I had the same problem the first time I got mine out at night, I could see behind me. On mine when I got it back from the dealer, I had the same problem. You need to take the fairing off to get to the headlite bucket and add a 5/16" thick washer behind the adjusting screw to push it lower. Ride safe Bob Link to comment Share on other sites More sharing options...
Motorcycle Mike Posted September 9, 2014 Author Share #4 Posted September 9, 2014 I found the bolt Ken is refering to. I'll try that when I get home. If not I hope your just refering to the outer fairing Bob. Or are you? Link to comment Share on other sites More sharing options...
kensattitude Posted September 9, 2014 Share #5 Posted September 9, 2014 It is a long winded bolt, don't give up cause it will suck it in. Link to comment Share on other sites More sharing options...
Motorcycle Mike Posted September 9, 2014 Author Share #6 Posted September 9, 2014 It is a long winded bolt, don't give up cause it will suck it in. Thanks Ken. I assume clockwise pulls it down? Link to comment Share on other sites More sharing options...
bigbob Posted September 9, 2014 Share #7 Posted September 9, 2014 I found the bolt Ken is refering to. I'll try that when I get home. If not I hope your just refering to the outer fairing Bob. Or are you? Yup, that be the one. It's been 3 years since I did that, so I don't remember all the details Good luck Bob Link to comment Share on other sites More sharing options...
Motorcycle Mike Posted September 10, 2014 Author Share #8 Posted September 10, 2014 Thanks Ken, that pulled it down real nice. Link to comment Share on other sites More sharing options...
