Huggy Posted July 4, 2014 Share #1 Posted July 4, 2014 I looked up seed bleeders and come up with ALL different thread sizes!!!!! What do I need for my 86 VR???? Link to comment Share on other sites More sharing options...
Rosie1965 Posted July 5, 2014 Share #2 Posted July 5, 2014 I used the SB8125L-L, works for all calipers and clutch slave. http://www.v4market.com/Brakes-Speed-Bleeder-pair_p_45.html Link to comment Share on other sites More sharing options...
Prairiehammer Posted July 5, 2014 Share #3 Posted July 5, 2014 I used the SB8125L-L, works for all calipers and clutch slave. http://www.v4market.com/Brakes-Speed-Bleeder-pair_p_45.html I used the SB8125L. Don't the SB8125LL stick out too far? You can also buy the Speed Bleeders direct from the manufacturer. Link to comment Share on other sites More sharing options...
Rosie1965 Posted July 5, 2014 Share #4 Posted July 5, 2014 I ordered the SB8125L from Amazon for my Venture and the SB8125L-L from the V4 market for my Magna. They were the exact same thing other than the ones from the V4 market cost less and came with the rubber caps. They don't seem too long. Link to comment Share on other sites More sharing options...
Condor Posted July 5, 2014 Share #5 Posted July 5, 2014 I ordered the SB8125L from Amazon for my Venture and the SB8125L-L from the V4 market for my Magna. They were the exact same thing other than the ones from the V4 market cost less and came with the rubber caps. They don't seem too long. One that will be too long is the one for the clutch slave. The longer type will make it a PITA getting the rubber cover to fit back on. Order the SB8125... The rest will take the L. Link to comment Share on other sites More sharing options...
Huggy Posted July 6, 2014 Author Share #6 Posted July 6, 2014 I was confused because when I looked them up they came in 8mm and 10mm. Now I didn't know if they where talking about length or diameter or what, just totally confused me. Link to comment Share on other sites More sharing options...
Condor Posted July 6, 2014 Share #7 Posted July 6, 2014 I was confused because when I looked them up they came in 8mm and 10mm. Now I didn't know if they where talking about length or diameter or what, just totally confused me. It's the diameter, and all 1stGens take the 8125 series bleeder... The stem lengths are reg, L, LL. The reg for the clutch, and the L...because it makes it a little easier to put the plastic drain line over... for the calipers. Link to comment Share on other sites More sharing options...
Huggy Posted July 12, 2014 Author Share #8 Posted July 12, 2014 OK Thanks. Link to comment Share on other sites More sharing options...
Ben Rollins Posted March 9, 2015 Share #9 Posted March 9, 2015 I am adding speed bleeders soon, like in the next day or so with the temps we have coming, should I use my mighty vac to bleed or pump, or both? Link to comment Share on other sites More sharing options...
bongobobny Posted March 9, 2015 Share #10 Posted March 9, 2015 Just for information, the 8 stands for 8mm diameter, and the 125 stands for the pitch, 1.25 turns per mm... Link to comment Share on other sites More sharing options...
Venturous Randy Posted March 9, 2015 Share #11 Posted March 9, 2015 I am adding speed bleeders soon, like in the next day or so with the temps we have coming, should I use my mighty vac to bleed or pump, or both? My opinion, so take it for what it's worth. When using speed bleeders, I like the pump better and I like to pump a lot of fluid as fast I can, without running the reservoir dry. I like to do this as with brake fluid, there seems to be enough viscosity to push air bubbles down the line into the caliper and then they will bleed out. If you pump too slow, the bubbles will rise back up the line and stay in the system. Also, this is on an 83 and I do not have a bleed valve in the top of my triple tree as the MKII's do. Randy Link to comment Share on other sites More sharing options...
