MasterGuns Posted May 2, 2014 Share #1 Posted May 2, 2014 Installed a brand new Odessy PC80 battery about 3 months ago. Just went out to take a ride and the bike wouldn't start. As a matter of fact the dash wouldn't even come on. So started troubleshooting. Nothing pulling power when connected. Removed fuses one at a time and no change in voltage. With the battery tender hooked up cannot get voltage above 11.57 even battery completely disconnected. So my question is can an Odessy PC80 fail that quickly? Was good yesterday. Guess I'll have to go to Wally World and get one of theirs if I want to ride today. I am now very disappointed in Odessy batteries. Masterguns Link to comment Share on other sites More sharing options...
valleycat Posted May 2, 2014 Share #2 Posted May 2, 2014 I'd go back to where you got the Odyssey. No way it should go that quick. Something is wrong with either your bike, or the battery. I had an Odyssey in my 2000 VL1500, and it was going strong when I sold it, and probably still is after three years +. Link to comment Share on other sites More sharing options...
YamahaLarry Posted May 2, 2014 Share #3 Posted May 2, 2014 I'd go back to where you got the Odyssey. No way it should go that quick. Something is wrong with either your bike, or the battery. I had an Odyssey in my 2000 VL1500, and it was going strong when I sold it, and probably still is after three years +. Fixing to have to buy a battery for my '07 VStar 650 before I sell it and I guess I need to stay away from Odyssey? The factory battery has been a good one. Bike has 39k miles and still has the original battery. It will crank the bike, but drags when engine is cold. Link to comment Share on other sites More sharing options...
Peder_y2k Posted May 2, 2014 Share #4 Posted May 2, 2014 Yes, even premium products have a few duds among all the good ones. Take it back for an exchange. "Not holding charge" -Pete, in Tacoma WA USA Link to comment Share on other sites More sharing options...
bongobobny Posted May 3, 2014 Share #5 Posted May 3, 2014 Yah! Not the first Odessey to fail after a short time, but they stand behind their warranty. With the higher new cost, most of us now go with the DEKA AGM. Skydoc_17 sells them at a good price! Link to comment Share on other sites More sharing options...
BlueSky Posted May 3, 2014 Share #6 Posted May 3, 2014 Put a charger on the battery and see if it will take a charge. If not, the battery is kaput. If it charges up properly, something is amiss with your motorcycle. Link to comment Share on other sites More sharing options...
xssquared Posted May 3, 2014 Share #7 Posted May 3, 2014 I worked in the factory where these batteries are made. They are generally very good quality but like anything made by man they can fail. Charge the battery and check the charging system. Don't just assume it is the battery is faulty if it is get it warranties and try another one before giving up. Give them a chance to make it right. After all it isn't often we can buy a product still made in the USA (Warrensburg MO). Link to comment Share on other sites More sharing options...
MasterGuns Posted May 3, 2014 Author Share #8 Posted May 3, 2014 First, I corrected the spelling of this battery as well as the model. I was in an extreme hurry while typing my first post and didn't have time to give everyone all the details so I unintentionally left out one crucial detail. That is that while connecting an accent light power line I accidently shorted out the switch power lead coming from the battery. As a matter of fact I think I may had shorted the same line out twice. I was also in a hurry trying to get the installation completed and didn't disconnect the negative battery cable even though I know I should had. You know the old adage "Haste makes waste". So could shorting out the power lead to the accent light switch destroy an Odyssey PC680? If so, then I'll never buy another one because I would now consider them as being too fragile. Never the less, could I have destroyed the battery myself? Masterguns Link to comment Share on other sites More sharing options...
BuddyRich Posted May 3, 2014 Share #9 Posted May 3, 2014 Battery Tender won't charge a gel cell properly I don't think. It may keep it topped off but can't get it charged from totally dead. Hook it up to a six or ten amp charger and let it charge it. I ran an oddesy down three times to totally dead leaving the ign switch on in the garage for a couple of days. It still lasted me about four years doing that. Link to comment Share on other sites More sharing options...
bongobobny Posted May 5, 2014 Share #10 Posted May 5, 2014 To answer your question, probably not. How hot did the wire you shorted get and how long was it shorted, a few milliseconds, about a second, more than a second?? Heck, just hitting the starter draws a whole lot of amps instantaneously... Link to comment Share on other sites More sharing options...
MasterGuns Posted May 5, 2014 Author Share #11 Posted May 5, 2014 Battery Tender won't charge a gel cell properly I don't think. It may keep it topped off but can't get it charged from totally dead. Hook it up to a six or ten amp charger and let it charge it. I ran an oddesy down three times to totally dead leaving the ign switch on in the garage for a couple of days. It still lasted me about four years doing that. Buddy, you are correct. Hooked up the Odyssey to a 10 amp charger yesterday for a couple hours then took it to have it load tested. It tested good. Just checked it and it is still holding at 13.10 volts. So I won't have to go to Wally World after all. Thanks for the guidance. Herb Link to comment Share on other sites More sharing options...
Eck Posted May 5, 2014 Share #12 Posted May 5, 2014 Good to hear your battery is OK... Cool Beans!!! Link to comment Share on other sites More sharing options...
