MasterGuns Posted December 11, 2012 Share #1 Posted December 11, 2012 Can someone give me a quick verbal (walkthru) of how to "properly" perform a compression check. Bike is an 86. I have a pretty good idea of how to check the compression, but since it has been literally years since I've done one on anything, I just need a quick review of the procedure. Here's how I would do one. Once the motor is exposed, I would 1) remove all the spark plugs 2) short out all the spark plug wires to not harm the CDI box 3) connect gauge 4) at full throttle, crank the motor over until max pressure is observed on the gauge for each cylinder 5) if low one tests low (what would be low??), squirt a little oil in that cylinder chamber then recheck 6) record all results Good compression would be where no one cylinder is more than 10 off from any other. Add anything you think I missed or should know before proceeding. Thanks Link to comment Share on other sites More sharing options...
SilvrT Posted December 11, 2012 Share #2 Posted December 11, 2012 Good compression would be where no one cylinder is more than 10 off from any other. if you have 3 at 150 and one at 140 (10 diff) ... you don't have a problem. From my old days of wrenching, I think we used a 25% factor so... 3 @ 150 1 @ .75 * 150 = 113 equates to a possible problem. now, this was when I worked on cars (V8 or straight 6) ... a 4 cyl might be a different % factor. Link to comment Share on other sites More sharing options...
van avery Posted December 12, 2012 Share #3 Posted December 12, 2012 You might put a battery charger on to make sure you don't run down the battery. Otherwise I believe you have it. Link to comment Share on other sites More sharing options...
Michel Posted December 12, 2012 Share #4 Posted December 12, 2012 What I made when I check compression. 1 : I start the bike for have a hot engine. 2 : I remove the carburators ( for have a maximun air entrance) 3 : I remove the 4 spark plug. 4: " short out all the spark plug wires to not harm the CDI box " In this condition I have this on my 1988 1200 venture 1 / 13,5 kg 2/ 14 kg 3/ 13 kg 4/ 14 kg michel Link to comment Share on other sites More sharing options...
MasterGuns Posted December 12, 2012 Author Share #5 Posted December 12, 2012 What I made when I check compression. 1 : I start the bike for have a hot engine. 2 : I remove the carburators ( for have a maximun air entrance) 3 : I remove the 4 spark plug. 4: " short out all the spark plug wires to not harm the CDI box " In this condition I have this on my 1988 1200 venture 1 / 13,5 kg 2/ 14 kg 3/ 13 kg 4/ 14 kg Compression should always be checked while the motor is cold. Any you don't need to remove the carburetors to do so. All else I agree with except an 88 Venture is a 1300 not a 1200/ Link to comment Share on other sites More sharing options...
Michel Posted December 12, 2012 Share #6 Posted December 12, 2012 Sorry but I have always check compression engine hot, before I works in mecanic , and we take pression like this. that right it s not indipensable to remove carburators...... In France 1200 venture: 1984 to 1988 1300 venture: 1989 to 1993 Here a picture of a 1200 venture 1988 http://img15.hostingpics.net/thumbs/mini_9166831988.jpg michel Link to comment Share on other sites More sharing options...
MasterGuns Posted December 12, 2012 Author Share #7 Posted December 12, 2012 Sorry but I have always check compression engine hot, before I works in mecanic , and we take pression like this. that right it s not indipensable to remove carburators...... In France 1200 venture: 1984 to 1988 1300 venture: 1989 to 1993 Here a picture of a 1200 venture 1988 http://img15.hostingpics.net/thumbs/mini_9166831988.jpg michel Wow, I didn't know that. Learn something new everyday. Thanks Link to comment Share on other sites More sharing options...
mmaleney Posted December 13, 2012 Share #8 Posted December 13, 2012 Why test a motor cold rather than hot ? Link to comment Share on other sites More sharing options...
ACE50 Posted December 13, 2012 Share #9 Posted December 13, 2012 So you don't burn yourself!!?? Link to comment Share on other sites More sharing options...
Black Owl Posted December 13, 2012 Share #10 Posted December 13, 2012 Just my 2 cents here. An engine should always be at normal operating temperature to obtain an accurate compression reading. Or so my daddy told me..... Link to comment Share on other sites More sharing options...
MasterGuns Posted December 13, 2012 Author Share #11 Posted December 13, 2012 Just my 2 cents here. An engine should always be at normal operating temperature to obtain an accurate compression reading. Or so my daddy told me..... I was taught the motor can be cold, or warmed. I suppose you could get it to normal operating temp but by time you pulled all the spark plugs and screwed in for the first cylinder it would already be under normal temp. Anyway, I was taught to perform this test when cold and add 5% to the numbers. Link to comment Share on other sites More sharing options...
Squidley Posted December 14, 2012 Share #12 Posted December 14, 2012 I too have always tested them cold, it was instructed to me that it would give a true idea if things were starting to wear. If you had a trouble cylinder, squirt a little oil in and that would suggest that the rings may be worn. I have always gone by 10% difference between the cylinders, take the highest reading and the lowest and if the difference is less than 10% thats good. Throttle wide open and crank till the needle quits moving..... Link to comment Share on other sites More sharing options...
Flyinfool Posted December 14, 2012 Share #13 Posted December 14, 2012 Why test a motor cold rather than hot ? When hot the engine was just splashing oil onto the cylinder walls. This will always give a higher reading do to the extra seal provided by the oil. While testing cold there will be less oil on the walls and you will get a better indication of the mechanical condition of the rings. This is why if you get a low reading you then squirt some oil into the cylinder to determine if the leak is rings or valves. Link to comment Share on other sites More sharing options...
playboy Posted December 14, 2012 Share #14 Posted December 14, 2012 When hot the engine was just splashing oil onto the cylinder walls. This will always give a higher reading do to the extra seal provided by the oil. While testing cold there will be less oil on the walls and you will get a better indication of the mechanical condition of the rings. This is why if you get a low reading you then squirt some oil into the cylinder to determine if the leak is rings or valves. Sounds like a caveman could do it. Link to comment Share on other sites More sharing options...
