New to me RSV-Hannigan Trike Check-Setup_Mod
First_N_Last
  • Replies 98
  • Created
  • Last Reply
Top Posters In This Topic
37 degrees today, but sunny with no wind so I went back to finishing off the final things.
Today's effort was to correct the "Previous Owner's" wiring for the fuel pumps.
When he wired up the Auxiliary Fuel Tank & pump, he decided to hook it up to accessory power.
Yes - when you turned the key to accessory to listen to the radio, etc. the fuel pumps had power.
I wasn't comfortable with that, so it now connected to ignition controlled power.
That was all I could do in the cold for today. Even the soldering iron wasn't happy.
JohnnyB
  • 2 months later...
Spring seems to have arrived so I am restarting my check/mod effort.
Yesterday's efforts were...
Finished my Air Intake checks & mods. I tried the full D-cutout on thus bike. Just like my 2008 RSV, the 2002 RSV found it too lean with the full d cut. So I left it with just an added 1/2 hole added to the factory cutout.
After that I spent about one hour changing the cheap Hannigan Trunk lock to a cheap T-Handle lock that works REALLY well.
Today is another nice weather day so - I'll be at it in less than one hour.
JohnB
Just got to my first break & here are the discoveries so far...
  • The CB was in it's mounting case, but none of the wires were hooked up. I'm going to check it out for receiving with a temporary hookup & see if it works. Then I'll connect it up & order/buy a CB antenna, mount & connector adapter. PO didn't bother with it I guess.
  • I found the fuel lines held on the fuel filter by plastic tie wraps (not even nylon). So I'm replacing them of course.
Back to the effort...
JohnB
I got the CB wired back up except for the antenna. A quick test shows that it works.
Now I just need to figure out the parts to get a firestick connected.
Changed the wiring on the MP3Venture to get rid of the switch & have power supplied by bike accessory instead of the C-Bus.
Then I changed the widshield mounting screws to my mod which uses faucet washers & steel washers to cushion the grip of the windshield to the fairing.
Now I get to ride in the nice weather until I get a CB antenna & alarm system.
JohnB
I'm raiding my tackle box for sinkers to try it out.
If it works let me know. I've got a lot of pure lead for when I was shooting black powder and also a bunch of wheel weight lead tined for cast bullet shooting. Oh and let us know which works best for the most return in gold. :stirthepot:
Larry
While I'm waiting to get all my Alarm & CB Antenna stuff...
I decided to take the "Ghost Rider" out on a 350+ mile cruise.
The trip started on I64 west out of Richmond for about 15 miles at 70+
- then got on rte250 west with speeds between 40 & 62
- in Charlottesville - hopped back on 64 & did 70+ up Afton mountain
- on the mountains, I got on the Blue Ridge Parkway & rode south
- got off the BRP at route 60 & drove east & home
Two problems were discovered:
  1. Trike was pinging with regular, but seems to work great with Premium
    - I am planning on changing my DynaTek profile from 3 to 2 (maybe)
  2. Close to home, I started to intermittently lose ignition on one of the cylinders
    - this turned out to be the red wire to the cylinder #1 coil
    - I had used a Y-patch to eliminate cutting/splicing the tach install
    - corrected by splicing & adding good connectors
Ignition is fully functional now - the pinging with unleaded will be retested to insure that it wasn't caused by the mis-firing cylinder #1.
Soon to be fully done & ready for a summer cruise to Alido, TX.
JohnB
  • 2 weeks later...
CB update:
  • Firestick II antenna is installed
  • CB receive works great
  • Rear transmit switch works
  • Front transmit switch doesn't work
So... on to the next stage of repair effort:
  • determined by monitoring Green wire on Clarion radio control side of cable
    12+ normal & ground when rear transmit switch is pushed
  • White wire at control side has no voltage - may be different from rear?
    front transmit switch on has no ground on other cable side
Repair effort will continue when the rain days pass
JohnB
CB update:
JohnB
Repair status determined tonight...
The front transmit button problem is most likely the transmit switch. The CB & Radio Control are functioning normally.
Next step is diss-assembly of the switch assembly.
JohnB
  • 4 weeks later...
JohnB
Just repaired the faulty front CB transmit switch. I had to totally disassemble the switch - fix it - then reassemble it. It was not much fun.
then I tuned the antenna...
chan1 - 1.5
chan40 - .5
antenna is a touch to short to adjust further, but the setting is good enough.
CB is now operational!
John
Well I doubled checked the pinging with different tanks of gas. Pinging with regular persisted.
Before changing the DynaTek profile, I checked the TPS adjustment.
The Throttle Position Sensor was an interesting thing to adjust. After persistence I managed to check the adjustment. It was 800 ohms at closed throttle & progressively increased as the throttle was opened to full with a max reading of about 4800 ohms. No adjustment was necessary.
The TPS if defective or miss-adjusted could have been the problem, but it wasn't.
So, I changed the profile from 3 to 2. Pinging is gone with regular gas now.
I now declare my Trike ready to ride.
This is the end of my entries to this thread.
JohnB
Glad your happy now.
How was the vacation John ?
Jay,
Sedona, AZ was great - weather was great - hiking was great - no cuts, sprains, etc. like some past years, for any of us four.
Sedona Eagle Rider wanted $205 (out the door) to rent a Harley, so we all passed on renting crotch heaters.
John
  • 1 year later...
UPDATE
Since I picked up the Trike, I had a little strange vibration above 74mph. I finally "got-a-round-to-it" & pulled both rear wheels off & got them spin balanced. The shop said they "were way off". Afterwards I ran the Trike up to 95 & it was smooth. I should have done that a long time ago, but getting those wheels off with a 12mm allen wrench is a pain.
While I had the wheels off, I checked out my rear gas tank vent hose. Filling my AUX tank has always been a pain & I had to almost drip the gas in to keep it from foaming out. Well this problem has been resolved now also. The vent hose came out of the tank - went up about 4 inches to loop around 3 times in an eight inch loop & then went down to the other drain/vent hoses. The hose has been shortened by about 4 feet now & is routed simply without rise & looping. Jees - why would someone have done that?
The Dynatek 3000 I put in failed & Dynatek replaced it with a new USB model. That model has been setup with 3 custom ignition profiles I have tried. It is pretty cool making your own curves, but probably a little complex for the average biker.
That is it - everything else is just running & making me happy. The rear tires seem like they will last forever. The front tire is the 1st of 2 tires I'm Testing for AVON Tires. The MT90 will come off in about 2000 miles & I'll put a different one on for wear/handling testing. Avon wants to have a front "Trike" rated tire to offer for us.
JohnB
  • 2 weeks later...
UPDATE
JohnB
Glad to hear you are getting things sorted out on the trike.
That would be fantastic if they do offer a trike specific front tire with a flatter profile to put more rubber on the road. Can you give us some pictures of these tires you're testing?
