A unique shifting problem
I had noted a couple of weeks ago that I was having a shifting problem. I was having a problem with the bike not staying in 1st and 5th gear. I could shift it into 1st gear and it would come back out unless I held the shifter down until I put it under a load. I was having the same problem with 5th and also having a problem with finding neutral.
I suspected I was having a détente problem and that was what it turned out to be. The spring that pulls in the détente roller arm was broken. I had a spare and was able to replace it by taking off the clutch side cover and down beside the clutch basket I could get to it. Some long needle nose pliers and I was good to go.
I wanted to post this as this is not a problem I have heard the Venture having. It appears that the spring was just worn enough to finally break.
RandyA
