Brake Pad Posted October 14, 2012 Share #1 Posted October 14, 2012 is there a picture showing where the ground wire is for the R/R ? I have the gas tank off, and I understand its on the right side of the bike near he neck. do I have to remove the other plastic plate, wrapped around the ignition? Just checking, for a lose ground Link to comment Share on other sites More sharing options...
LilBeaver Posted October 15, 2012 Share #2 Posted October 15, 2012 If memory serves me correctly you DO need to remove the plastic thing on the right side of the 'neck' area near the ignition to get that ground bolt. Link to comment Share on other sites More sharing options...
bongobobny Posted October 15, 2012 Share #3 Posted October 15, 2012 I have a second gen frame with attached wiring harness seting in my shed, and I can see the ground strap and it looks like it would bolt on somewhere under the plastic wiring cover. 4 phillips screws get it off, but pay attention to where each screw goes as there is 2 lengths... Link to comment Share on other sites More sharing options...
BradT Posted October 15, 2012 Share #4 Posted October 15, 2012 The Ground wire is braided and surrounded in large plastic cover. Brad Link to comment Share on other sites More sharing options...
