Freebird Posted August 26, 2012 Share #1 Posted August 26, 2012 A HUGE thank you to BigBear for taking the time to shoot videos of the proper way to use the valve shim tool. I would like to encourage any of you who has the time to produce such videos. They will make a GREAT addition to our tech library. http://www.venturerider.org/forum/showthread.php?p=711236#post711236 Link to comment Share on other sites More sharing options...
RandyR Posted August 26, 2012 Share #2 Posted August 26, 2012 Don, thanks A couple comments The first video is blank - nada. The second one is good, except, at the end the tool is reversed back over an empty shim bucket after removing a shim. I would never do that until after replacing the shim. The video might give a newbie the impression that the tool is to be removed, which should never happen until both buckets have shims (old or new) in them. The 3rd and 4th are redundent. I'd delete the 4th. The video should be helpful to someone new to the procedure. Link to comment Share on other sites More sharing options...
Freebird Posted August 26, 2012 Author Share #3 Posted August 26, 2012 Thank you for the comments. I've deleted the 4th one. The first one is working fine for me though. Link to comment Share on other sites More sharing options...
