Clutch won't completely disengage????
Nemo
Clutch won't competely disengage? How do I adjust the clutch pull cable? Coming to a stop and holding the clutch lever in, the bike wants to creep ahead. Sometimes this will stall the engine and then it's hard to crank over because of the low gear drag on the starter. I know it's probably an easy fix, but I need your help. Owen.
Nemo-
Easy to do! Likely the fluid is old and discolored.
Open the clutch master cylinder.
With an eye dropper, remove the fluid and wipe it clean.
Fill with DOT3 brake fluid
Go to the slave cylinder end, 8mm wrench
Put a clear piece of hose on the bleed valve and run it into container.
Pump up and hold the clutch lever - release the bleeder valve and reclose
Release and clutch lever and repeat until the fluid in the clutch line in changed out (if discolored, until it's completely clear).
Be sure keep fluid in the master cylinder.
Finally, have the master cylinder about 2/3 full and replace the cap.
Ride, ride, ride!!
Thanks David! Good instructions. Sounds like that will work. Got to take to boss out to dinner pretty soon now, so I'll attack that project in the morning. Man I love this forum! Owen.
But, now I have probably really dumb questions. Where is this slave cylinder located and what does it look like? Sorry!
Left side of the bike (while sitting on it) the 2 circular covers on the motor. The fwd one is your stator cover, the one behind it, towards the rear of the bike is your middle gear cover. There is a 1 1/4" square rubber pad about halfway up the distance and directly between the covers. Flip it up and there is the bleeder for the clutch...
Wow! You guys are one "Smart" group. And "Thanks" to you too, Brad. You make it look too easy! I'm learning though. It makes me feel good all over, more than anywhere else! Ha! Owen
Yep, this is a great site with some of the greatest friends you you will ever make.
On this alone you've got more than your $12 worth in information.
Nemo-
Fill with DOT3 brake fluid :no-no-no::no-no-no::no-no-no:
Ride, ride, ride!!
I thought these bikes used DOT 4 brake fluid hmm have to run to the shop to check my owners manual.
Yep Dot 4 page 7-29 owners manual :cool10::cool10::cool10:
boy i hate this i changed the color to highlit something and now it wont go back to black
i got it back in black now oh yea its dot 4 or 5. 5 is expensive and sometimes hard to find dot 4 not so much easier to find and not muchmore then dot 3 but better i think dont know just know it cost more and yammahaaaaa says put it in :whistling:
BE VERY CAREFUL ..cover all your plastic (ABS) with a thick rag.
When you pump the clutch lever it will spit it out at you. I use a hand vacuum pump I got at Harbor Freight. I used the vacuum pump to remove the fluid in the reservoir then used it to bleed all the fluid through the lines from the bottom bleeder.
The fluid will destroy your plastic..so cover it all !
I noticed one post mentioned DOT 5. DOT 5 is not compatible with any of the others. There is a DOT 5.5 that is compatible with 3 or 4. The higher the number, the higher the boiling point.
I think he meant the 5.5, but typed it 5. 5 (possibly to confuse 2nd genners),,,
