Diddly Posted July 23, 2012 Share #1 Posted July 23, 2012 Hi. I'm trying to completely remove the exhaust. The mufflers, front down pipes and lower chamber/collector box are off but how do I get the rear downpipes off the bike? I've managed to get the cover plate out but the down pipe is proving awkward. There is obviously a knack but I haven't got it. Has anyone else any experience of removing this part? Thanks in advance, Fi Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 23, 2012 Share #2 Posted July 23, 2012 I remember having a time with it but don't remember any tricks...sorry.Seems I had to force it a little someway. Link to comment Share on other sites More sharing options...
Rocket Posted July 24, 2012 Share #3 Posted July 24, 2012 Hi. I'm trying to completely remove the exhaust. The mufflers, front down pipes and lower chamber/collector box are off but how do I get the rear downpipes off the bike? I've managed to get the cover plate out but the down pipe is proving awkward. There is obviously a knack but I haven't got it. Has anyone else any experience of removing this part? Thanks in advance, Fi Undo the clamps, move the rear master cylinder reserviour out of the way (outside of the frame) & work it out the right side. May need to shift the master cylinder as well. There is no need to disconnect the lines for the brake fluid. Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 24, 2012 Share #4 Posted July 24, 2012 Undo the clamps, move the rear master cylinder reserviour out of the way (outside of the frame) & work it out the right side. May need to shift the master cylinder as well. There is no need to disconnect the lines for the brake fluid. Yeah there was that.... I was trying to remember. My head just ain't what it used ta be.. Link to comment Share on other sites More sharing options...
Flyinfool Posted July 24, 2012 Share #5 Posted July 24, 2012 I haven't done it but since he wants everything off, can the collector be removed before the back pipes and then wiggle the back pipes out the bottom? I'm just pukin out ideas here. Yeah there was that.... I was trying to remember. My head just ain't what it used ta be.. Head butting oak trees have anything to do with that???? Link to comment Share on other sites More sharing options...
Rocket Posted July 25, 2012 Share #6 Posted July 25, 2012 I haven't done it but since he wants everything off, can the collector be removed before the back pipes and then wiggle the back pipes out the bottom? I'm just pukin out ideas here. Head butting oak trees have anything to do with that???? Collector is already off & no room to pull the rear pipes out the bottom, thus pulling them out the side. Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 25, 2012 Share #7 Posted July 25, 2012 I haven't done it but since he wants everything off, can the collector be removed before the back pipes and then wiggle the back pipes out the bottom? I'm just pukin out ideas here. Head butting oak trees have anything to do with that???? The tree ain't complaining.... Link to comment Share on other sites More sharing options...
