xxRoger1xx Posted July 8, 2012 Share #1 Posted July 8, 2012 The bike I just purchased is without the lower air deflectors. It is a 1999. Does anyone no where to get replacements with mounting brackets. Roger:fingers-crossed-emo Link to comment Share on other sites More sharing options...
Bummer Posted July 8, 2012 Share #2 Posted July 8, 2012 I got the stainless ones from DiamondR accessories. Unfortunately right now it looks like all they have are the brackets. You can try bidding on the ones on Ebay. That has to be a better deal than paying $250 for a complete set through a Yamaha dealer. Link to comment Share on other sites More sharing options...
xxRoger1xx Posted July 9, 2012 Author Share #3 Posted July 9, 2012 thanks Bummer. I have been looking for the diamond r site. These things are sure pricy. Link to comment Share on other sites More sharing options...
Carbon_One Posted July 9, 2012 Share #4 Posted July 9, 2012 I've got stock brackets you can have if you can find the plastic deflectors. Let me know. Larry Link to comment Share on other sites More sharing options...
Bobby G Posted July 9, 2012 Share #5 Posted July 9, 2012 I have the replacement brackets on order at the dealer - - they are pretty cheap, but they break easily due to the constant vibration on the deflector, so I'm installing a rubber bumper behind each one to rest against the fork. The pricy part is the chrome piece on the outer part of the deflector - - about $80. I'm making my own deflectors from high impact ABS plastic that I got at Lowes. Once you get the light bar out of the way, it's a pretty easy install. Link to comment Share on other sites More sharing options...
calperin Posted July 9, 2012 Share #6 Posted July 9, 2012 I've got stock brackets you can have if you can find the plastic deflectors. Let me know. Larry Larry, If you don't sell those brackets, I'm going to purchase from you. Mike's bike had those broken. Thanks Carlos Link to comment Share on other sites More sharing options...
Carbon_One Posted July 9, 2012 Share #7 Posted July 9, 2012 Larry, If you don't sell those brackets, I'm going to purchase from you. Mike's bike had those broken. Thanks Carlos No cost Carlos. Your's for free. Larry Link to comment Share on other sites More sharing options...
MikeWa Posted July 9, 2012 Share #8 Posted July 9, 2012 Put a small rubber or foam pad under the lower end of the deflector brackets. Between the rubber stop and the upper shock. It will absorb vibration. I just glued mine to the upper shock. Mike Link to comment Share on other sites More sharing options...
etcswjoe Posted July 9, 2012 Share #9 Posted July 9, 2012 Lost one two weeks ago, thought I would try to come up with something unique Link to comment Share on other sites More sharing options...
playboy Posted July 9, 2012 Share #10 Posted July 9, 2012 Not to replace the wings but to hopefully prevent there breaking the mount. First I removed the OEM rubber bumpers ( already had lost one ). At Lowe's on the hardware isle where all the blue drawers are there should be a drawer with and assortment of rubber stoppers ( blk round wedge shape ) in various sizes. Like bottle stoppers anyway I picked out two of them approx size of 3/8 " on the big end and approx. 1" in length. Also in the same drawers will be stainless bolts and screws. Get a cpl of stainless pan head screws I think #10 x 1/4". Make a small pilot hole with a drill bit in the big end of the rubber stopper. Slightly smaller than the screws you purchased. Remove the wings from the brackets and attach your rubber stoppers through the hole left by the OEM bumpers with the stainless screws. Reattach everything to bike and trim your new bumpers to fit without placing stress on the mounts. I had to remove approx. 1/4" to 3/8" from mine from the small end so that they just touched the fork tubes. I don't have the spacer on my light bar but if you do you should have enough rubber to support them and probably wont have to trim much if any. I can post pics later if anyone needs them but I would have to go take everything back apart. I did this awhile back before I learned the value of taking pics of everything you do on these bikes so you can pass it along. Hope this helps Link to comment Share on other sites More sharing options...
