RedRider Posted June 23, 2012 Share #1 Posted June 23, 2012 Which way does this spacer go on the rear wheel? This spacer goes against the rear wheel bearing and is the seal surface the seal rides against. There is a raised shoulder on one side while the other is flat. Pictures of both are attached. I am assuming the raised part goes against the bearing since it is the same diameter are the inner race. And yes, those are the balls from the rear wheel bearing. Not good. RR Link to comment Share on other sites More sharing options...
mbelik Posted June 23, 2012 Share #2 Posted June 23, 2012 The flange goes on the inside of the hub. Link to comment Share on other sites More sharing options...
RedRider Posted June 23, 2012 Author Share #3 Posted June 23, 2012 Thought so. Thanks. RR Link to comment Share on other sites More sharing options...
etcswjoe Posted June 23, 2012 Share #4 Posted June 23, 2012 I actually had to go look. Link to comment Share on other sites More sharing options...
Yammer Dan Posted June 23, 2012 Share #5 Posted June 23, 2012 I was thinking.... Link to comment Share on other sites More sharing options...
DragonRider Posted June 23, 2012 Share #6 Posted June 23, 2012 You can get hurt that way..........................:bang head: I was thinking.... Link to comment Share on other sites More sharing options...
Yammer Dan Posted June 24, 2012 Share #7 Posted June 24, 2012 You can get hurt that way..........................:bang head: Just did enough to give me a headache..... Link to comment Share on other sites More sharing options...
XV1100SE Posted June 24, 2012 Share #8 Posted June 24, 2012 1st time I take something apart I'll often take pictures for each step so I know how it goes back together. I'll use different bags for bolts and parts and label them for where they go. Link to comment Share on other sites More sharing options...
RedRider Posted June 24, 2012 Author Share #9 Posted June 24, 2012 I often do that too. Bought 12 spot muffin tins to keep nuts and bolts in with each opening labelled. The tins are teflon coated. Write what's in each hole with a sharpie. When done, a quick shot of brake cleaner and it all wipes clean. Just don't try to bake muffins with it afterwards. I've taken off the rear wheel so often I wasn't as careful as usual. In the end, I had it on right. Was just questioning it since the bearing went out. This was caused by something else (still investigating, but it wasn't this spacer). Just trying to cover all the bases. RR Link to comment Share on other sites More sharing options...
Squeeze Posted June 24, 2012 Share #10 Posted June 24, 2012 A ruined Ball Bearing usualy is caused by tightening down the Axle without the Collar/inner Race on the left Side NEedle Bearing present. Link to comment Share on other sites More sharing options...
