jtfromnc Posted January 25, 2012 Share #1 Posted January 25, 2012 I have a 1984 Venture with the 1200cc engine on it (locked up), will a 1985 1300cc mount up to my 1984 frame and swing drive arm? Also will the electrical plug in as well or will I have to do mods to make it work. Thanks any help and or pictures would be appreciated. Link to comment Share on other sites More sharing options...
Yammer Dan Posted January 25, 2012 Share #2 Posted January 25, 2012 Will fit right in there. Why is the 84 locked up? It would take a lot for me to give up on one of those things. Link to comment Share on other sites More sharing options...
dingy Posted January 25, 2012 Share #3 Posted January 25, 2012 An 85 is a 1200, not a 1300. 86 was first year for 1300. Otherwise there are no wiring changes, TCI is the same. It should be a straight swap. What pictures do you need, I have a 1000 pictures (at least) of an 83 converted to a 1300 from an 88. Gary Link to comment Share on other sites More sharing options...
GaryZ Posted January 25, 2012 Share #4 Posted January 25, 2012 The 1986 1300 engine was a direct swap for the 1200 in my 1985. The only modification would be to the carbs, if you reuse them from the 1200. A spacer on the needles and 2.5 turns out on the low-speed circuit is good. Link to comment Share on other sites More sharing options...
