Chaharly Posted January 19, 2012 Share #1 Posted January 19, 2012 I want to remove the carb from my 83 because the jets are plugged. I cant get the lines loose on it because its cold out, and i dont want to ruin any of the rubber hoses. Whats a good way to get the hoses off without tearing them? I was thinking about some penetrating oil, WD 40, or a hair drier. What are some suggestions that you guys have that could possibly help me. Any help would be appreciated. Thanks!!! -CJ Link to comment Share on other sites More sharing options...
muaymendez1 Posted January 19, 2012 Share #2 Posted January 19, 2012 If they are stuck that bad.It may bee time for new hoses. I can see thr hoses not bending easily but if they are not coming off they may be stuck sure to previous heat. A scribe to lift a small edge enough to fit a straw of a spray lube should help. Link to comment Share on other sites More sharing options...
Eck Posted January 19, 2012 Share #3 Posted January 19, 2012 hair drier. Link to comment Share on other sites More sharing options...
Marcarl Posted January 19, 2012 Share #4 Posted January 19, 2012 Make sure you push them off with a screwdriver, don't try to pull them, they'll just get tighter. As Eck said, use a hair dryer to warm them, and then push on the end of the hose to remove with a flat screw driver. Link to comment Share on other sites More sharing options...
CaptainJoe Posted January 19, 2012 Share #5 Posted January 19, 2012 (edited) Just make sure you have the gas petcock turned off and a fire estinguisher close by... probably not much danger doing it with a hair dryer but I'm thinkng some well placed hot water(say from a tea kettle) would be a lot safer. OR My wife bought this little steamer deal for under $20... and would definately warm up a cold hose.... Edited January 19, 2012 by CaptainJoe Link to comment Share on other sites More sharing options...
RedRider Posted January 19, 2012 Share #6 Posted January 19, 2012 Get a small right angle mechanics pic. Run it up the hose end and pass it around the carb tube the hose is attached to. Or, wait 'til spring when it is warmer. RR Link to comment Share on other sites More sharing options...
