Guest Slab_Ryder Posted September 2, 2011 Share #1 Posted September 2, 2011 I recently had a Baron's Tach installed on my 08 RSV. Prior to installing, I set the Cold ERPM at 750 (by ear (old Submarine Sornaman Training)), after choking when starting. Once Warm (after riding 2 blocks), the warm Idle ERPM increased to around 950-1000. After installing Tach, I increased the Cold Idle ERPM to 1000. Once Warm (after riding 2 blocks), the warm Idle ERPM increases to around 1150. Is 1000 ERPM considered an optimal range? Was 750 ERPM too low? Link to comment Share on other sites More sharing options...
gibvel Posted September 2, 2011 Share #2 Posted September 2, 2011 Service manual say 950-1050 for idle speed. Link to comment Share on other sites More sharing options...
Guest Slab_Ryder Posted September 2, 2011 Share #3 Posted September 2, 2011 Thanks!! Link to comment Share on other sites More sharing options...
MikeWa Posted September 2, 2011 Share #4 Posted September 2, 2011 As you increase the idle RPM the trans starts to slam going into first gear. Since I don't like this I set my warm RPM just under 950. Mike Link to comment Share on other sites More sharing options...
Guest Slab_Ryder Posted September 2, 2011 Share #5 Posted September 2, 2011 Good point. I set my Cold at 1000 RPM, once warmed up I was hovering between 1200-1250. Going to drop it down to 950-975 Warm, when I get off the road tonight. Link to comment Share on other sites More sharing options...
N3FOL Posted September 2, 2011 Share #6 Posted September 2, 2011 FWIW, I've never looked at my cold rpm and not measured. I set my warm rpm on the high side of the recommended idle. Link to comment Share on other sites More sharing options...
