johnbroughman Posted August 30, 2011 Share #1 Posted August 30, 2011 Alright, the valve adjustment on my 01RSV and the clutch upgrade, new friction plates and spring, all is well and working beautifully. The vave adjustment, replaced 14 of the 16 shims, they all were ultra tight, caught it just in time at 85,000 miles, anyone doing this be extra sure of the crankcase vent hose routing, mine was crimped, causing the cover gaskets to blow, after 4 tear downs and a lot of head scratching, finally found it, the clutch upgrade was a snap, less than 2 hours and works perfect, a great big thank you to SkyDoc for the kit and the invaluable help with everything especailly the quick shipment of parts and kits. Thanks to the knowledgeable help of the great site, and anyone looking to do clutch up grade I suggest you contack SkyDoc for the kit. On the Road Again, its good for another 85,000. JB:whistling: Link to comment Share on other sites More sharing options...
