VstarAl Posted August 24, 2011 Share #1 Posted August 24, 2011 Good Day: I have an '07 Venture and was searching for the thickness specs of the brake rotors. (I found the specs for the 96-'01 Royal Stars, but not specific to the Venture.) I plan on replacing my front tire this weekend, and if I had to replace the rotors, I would do so at the same time. I have 19,700 miles on the bike. I already replaced the rear tire and brake pads around 14,000 miles. Thanks! Link to comment Share on other sites More sharing options...
dingy Posted August 24, 2011 Share #2 Posted August 24, 2011 Attached is a cut from the RSV service manual. It doesn't indicate a tolerance value in right column. Gary Link to comment Share on other sites More sharing options...
