bilko1 Posted August 22, 2011 Share #1 Posted August 22, 2011 I am looking at Tires for my 83, I now have avon. I wanted to find out if any one has tryed a lower profile to elimanate the tippie toe stance I have at a stop. (I have a 29 inch inseam). Link to comment Share on other sites More sharing options...
Venturous Randy Posted August 23, 2011 Share #2 Posted August 23, 2011 I have a shorter inseam than you do and the best thing I did was to pick up a used Corbin seat that needed some work and I removed about 1 1/2 inches of foam from the drivers seat. Not only am I more able to touch the ground, but the seat is much more comfortable. RandyA Link to comment Share on other sites More sharing options...
bilko1 Posted August 23, 2011 Author Share #3 Posted August 23, 2011 I have a shorter inseam than you do and the best thing I did was to pick up a used Corbin seat that needed some work and I removed about 1 1/2 inches of foam from the drivers seat. Not only am I more able to touch the ground, but the seat is much more comfortable. RandyA Last night the (worden,) opps the wife:bighug: said I realy have a 27 in inseam. it seams I'm shorter:depressed: than I thought. Link to comment Share on other sites More sharing options...
Venturous Randy Posted August 23, 2011 Share #4 Posted August 23, 2011 Last night the (worden,) opps the wife:bighug: said I realy have a 27 in inseam. it seams I'm shorter:depressed: than I thought. At least she didn't tell you that something else was two inches shorter than you thought. RandyA Link to comment Share on other sites More sharing options...
bilko1 Posted August 30, 2011 Author Share #5 Posted August 30, 2011 At least she didn't tell you that something else was two inches shorter than you thought. RandyA If it was,:whistling:I wouldn't be able to find it:whistling: Link to comment Share on other sites More sharing options...
skydoc_17 Posted August 30, 2011 Share #6 Posted August 30, 2011 I have a lower profile tire mounted on a front rim for my First Gen. when I go VROD hunting, or to the drag strip. The biggest problem is the speedo is mounted on the front axle, and the 100/80/18 tire throws the speedo WAY off. The other thing is when you bank right or left to go into a turn, you better have a spare pair of underpants, because my 87'VR will lean so quickly that you'll be screaming like a school girl! For straight line, drag race type riding, it helps keep the front end down, and the feel of the road is very positive. BUT it does make the steering a bit "twitchy". (to say the least) Other things to consider would be shorter front bearing life, and I spun the speedo needle off of my gage cluster, and smoked a speedo cable. For touring type riding, this mod would be very hard on the front end of the bike and hard on the rider as well. (with the front end lowered, you are "posting up" on your arms constantly) I'm not sayin' it can't be done, just sayin' it ain't gonna be FUN. Earl Link to comment Share on other sites More sharing options...
Ndiaz Posted August 30, 2011 Share #7 Posted August 30, 2011 There are improvements that can be made to a 1980's motorcycle, the 1st-gen Venture -- tires, brakes, cables, battery, fork brace, etc. One thing is to improve the bike, which many of us have done, thanks to Earl and others in this forum. Yet another is to change the bike so drastically it becomes a totally different animal, to the point of being unrecognizable, even unrideable. Tire size is something that should not be messed with, as it changes totally the nature of the ride. Nick Diaz Middletown, MD Link to comment Share on other sites More sharing options...
tazmocycle Posted August 31, 2011 Share #8 Posted August 31, 2011 if you lower the front you need to lwer the backend to match to keep the bike more stable. Link to comment Share on other sites More sharing options...
bilko1 Posted August 31, 2011 Author Share #9 Posted August 31, 2011 if you lower the front you need to lwer the backend to match to keep the bike more stable. I was thinking of going from the stock 120/90 in front to a 120/70, stock 140/90 in rear to a 140/70, so the diffrence in hight would be the same front and rear. :detective:Has anyone had a chance to ride an 83-85 with this tire combo on it? Bilko Link to comment Share on other sites More sharing options...
mmaleney Posted August 31, 2011 Share #10 Posted August 31, 2011 Yo may drop down to mid 30's on the MPG, the bike will feel like it's in 4th gear on the highway, but lots of power everywhere Link to comment Share on other sites More sharing options...
