junkyardog53 Posted May 2, 2011 Share #1 Posted May 2, 2011 i have been running my 2007 on premium gas...can i down grade to regular...tring to save some cost without hurting the engine....thanks Link to comment Share on other sites More sharing options...
ken Posted May 2, 2011 Share #2 Posted May 2, 2011 Yes....yes you can! I have always ran with 89oct. Link to comment Share on other sites More sharing options...
Sleeperhawk Posted May 2, 2011 Share #3 Posted May 2, 2011 I hope the dealer did not tell you to run premium. This bike runs on regular, another benefit over HD and others that require premium. Link to comment Share on other sites More sharing options...
BOO Posted May 2, 2011 Share #4 Posted May 2, 2011 I have always run 89 and will run the 87 if I am down south were they have it. Runs fine and gas mileage does not suffer. BOO Link to comment Share on other sites More sharing options...
Freebird Posted May 2, 2011 Share #5 Posted May 2, 2011 I've run 87 in mine since it was new in 1999. I've tried higher octanes maybe a half dozen times and have NEVER seen any benefit. Link to comment Share on other sites More sharing options...
V7Goose Posted May 2, 2011 Share #6 Posted May 2, 2011 Your bike is specifically rated for use with REGULAR fuel (87 R+M octane). Unless your engine knocks on regular fuel, use of any higher octane has absolutely ZERO value at all (except to the oil companies taking your money). It will NOT run smoother, you will NOT get better fuel economy, you will NOT get more power, etc. etc. etc. And since your engine is rated for 87 octane fuel, it will NOT knock when using it unless there is something wrong with your bike. And in the Rocky Mountains where they sell 85 octane regular, you will find that your bike runs fine on that, too. Goose Link to comment Share on other sites More sharing options...
bongobobny Posted May 2, 2011 Share #7 Posted May 2, 2011 yup!!!!! Quit wasting your money!!!!! Link to comment Share on other sites More sharing options...
KiteSquid Posted May 2, 2011 Share #8 Posted May 2, 2011 (edited) ALSO Premium has about 4% less BTU per gallon than regular, so you pay more for less enegery per gallon. The oil compaines LOVE getting more for less..... Edited May 2, 2011 by KiteSquid Link to comment Share on other sites More sharing options...
Chinto Posted May 3, 2011 Share #9 Posted May 3, 2011 Take the cost difference between premium and regular and buy some safety chrome. Your owners manual tells you to run regular 87. Mine has never had anything but regular from day one and runs great. Stop wasting Link to comment Share on other sites More sharing options...
twigg Posted May 3, 2011 Share #10 Posted May 3, 2011 i have been running my 2007 on premium gas...can i down grade to regular...tring to save some cost without hurting the engine....thanks There was a recent consumer test in the UK about this issue. The findings were simple. There is about a 1 1/2% improvement in fuel economy, and comparative reduction in wear, for an average price premium of 5%. The conclusion was simple. If you choose to run Premium gas blends when your engine doesn't need it, you will pay more for gas and get no discernible benefit .... but the next owner of the bike will thank you! Link to comment Share on other sites More sharing options...
V7Goose Posted May 3, 2011 Share #11 Posted May 3, 2011 There was a recent consumer test in the UK about this issue. The findings were simple. There is about a 1 1/2% improvement in fuel economy, and comparative reduction in wear, for an average price premium of 5%. The conclusion was simple. If you choose to run Premium gas blends when your engine doesn't need it, you will pay more for gas and get no discernible benefit .... but the next owner of the bike will thank you! I have not heard of this test, nor do I believe the stated results. This oft-repeated claim is nothing but pure hokum. Facts are easy to find by anyone interested in doing even minor research. Here are a couple of links: http://www.consumerenergycenter.org/transportation/consumer_tips/regular_vs_premium.html http://www.scientificamerican.com/article.cfm?id=fact-or-fiction-premium-g http://www.usatoday.com/money/autos/2003-07-30-premiumgas_x.htm Note that the ONLY references to any loss of power on regular fuel all refer to engines that are specifically designed for a higher octane. Usually this comes from an engine with knock sensors and electronic timing adjustments or variable valve timing. The reason an engine like that can loose some peak power with non-premium fuel is because the engine controls dial back the timing advance to stop the knocking. But like we said above, the owners manual tells you this engine is specifically designed for 87 R+M octane fuel. So there is NO improved economy and NO reduction in engine wear if you choose to spend the extra money on premium. Goose Link to comment Share on other sites More sharing options...
Rick Haywood Posted May 3, 2011 Share #12 Posted May 3, 2011 All the higher octane is is an anti knock agent. nothing more nothing less Link to comment Share on other sites More sharing options...
bongobobny Posted May 3, 2011 Share #13 Posted May 3, 2011 Yah!! Did a study with my cage several years ago and found by going from regular to middle premium I got slightly better MPG's but my cost per mile went waaaaaay up in comparison!! Unless you have a pronounced ping with regular, which suggests something is wrong, you are throwing your money away. In some cases with cages, you are actually doing more harm than good using premium when regular is called for... Link to comment Share on other sites More sharing options...
uechi kid Posted May 3, 2011 Share #14 Posted May 3, 2011 California models must be different. My owners manual says run premium. Link to comment Share on other sites More sharing options...
Venturous Randy Posted May 3, 2011 Share #15 Posted May 3, 2011 The only advantage to running premium in any engine at 9.5 to 1 compression ratio is being able to advance the timing more, but in a normal engine and especially an engine with knock sensors, or non adjustable timing, it is a moot point. RandyA Link to comment Share on other sites More sharing options...
V7Goose Posted May 3, 2011 Share #16 Posted May 3, 2011 California models must be different. My owners manual says run premium. I have no idea what manual you are looking at, but the actual Yamaha Owner's Manual for the 2008 XVZ13TFX© and XVZ13TFSX© (includes California models) specifically says this on page 3-11: "Your Yamaha engine has been designed to use regular unleaded gasoline with a pump octane number [(R+M)/2] of 86 octane or higher" Doesn't leave much room for interpretation... Goose Link to comment Share on other sites More sharing options...
twigg Posted May 3, 2011 Share #17 Posted May 3, 2011 California models must be different. My owners manual says run premium. Possibly because they were tuned for minimum emissions. That is as lean as possible, with the ignition advanced as far as possible .... but maybe not and there is an easy way to tell. Run the tank empty and add a couple of gallons of Regular. Find a hill and accelerate up it in a slightly higher gear than normal. If it "pinks" you will hear it. If it doesn't, then you are good to go on Regular. Link to comment Share on other sites More sharing options...
junkyardog53 Posted May 4, 2011 Author Share #18 Posted May 4, 2011 want to thank everyone for their info as always your comments are always very valuable to me....thanks everyone Link to comment Share on other sites More sharing options...
Condor Posted May 4, 2011 Share #19 Posted May 4, 2011 California models must be different. My owners manual says run premium. Interesting... The service manual for my California '99RSV just says regular. Not even an octane rating..??? Link to comment Share on other sites More sharing options...
uechi kid Posted May 9, 2011 Share #20 Posted May 9, 2011 I have no idea what manual you are looking at, but the actual Yamaha Owner's Manual for the 2008 XVZ13TFX© and XVZ13TFSX© (includes California models) specifically says this on page 3-11: "Your Yamaha engine has been designed to use regular unleaded gasoline with a pump octane number [(R+M)/2] of 86 octane or higher" Doesn't leave much room for interpretation... Goose I stand corrected. I sure thought I read it was suppose to run premium. I'll be saving a little money in the future. Thanks Link to comment Share on other sites More sharing options...
Galapagos Posted May 9, 2011 Share #21 Posted May 9, 2011 http://www.ftc.gov/bcp/edu/pubs/consumer/autos/aut12.shtm Link to comment Share on other sites More sharing options...
