fredster66 Posted February 15, 2011 Share #1 Posted February 15, 2011 I hate starting a new thread on an old topic, but I can't seem to find what I'm looking for. I bought a set of Baron Nasty Boy 4-2-4 pipes for my RSTD last year and ran them for about 1/2 the season. Just about every thread I found out here says they sound great, but mine sound raspy and a lot like the glass packs I put on my old Mustang. I thought they came without glass. They also feel like there is more back pressure than my old Samsons (which sounded and performed much better). When I goose the throttle they are much slower to respond than my old Samsons did. Before re-chroming and putting the Samsons back on, anyone have a cure for me? PS How do I get the freakin' baffles out? They get stuck at the end of the pipe. Much thanks to anyone who can help out.. Link to comment Share on other sites More sharing options...
Sling Posted February 15, 2011 Share #2 Posted February 15, 2011 I had the baron pipes on my bike for a while. I repacked the baffles. The way I got my baffles out was as follows: I removed the tips,and squirted WD-40 into the pipes. I got a sanding drum arbor (see picture below) pushed it in then tightened the nut which expanded the arbor and locked it in place. I used a vice grip plyers attached to a slap hammer and basicaly slapped them out. Repacked them and reinstalled them. My wife and i weren't too happy with them so I went back to the stock pipes. hope this helps. Link to comment Share on other sites More sharing options...
warriorhoneybee Posted February 15, 2011 Share #3 Posted February 15, 2011 wish i could help,i have the 4-2-4 nastys and love the way mine sound and perform but i think my baffels are out. good luck with that. when i crack my throttle the bike lunges forward and i've been told by alot of others here that heard it in asheville last year that they thought it had a great sound to it,maybe i just finaly got lucky. Link to comment Share on other sites More sharing options...
Raven1300 Posted October 11, 2021 Share #4 Posted October 11, 2021 I have an 05 Tour deluxe with the Yamaha chrome intakes with K&N filters and have been running the 4-2-4 nasty boys with the fiber glass wrapped baffles for 30,000 miles now , this weekend I completly removed the baffles and the bike sounds and runs Awesome, my question is: Is it ok to run the bike like that without rejetting the carbs?...............Thanks Link to comment Share on other sites More sharing options...
saddlebum Posted October 13, 2021 Share #5 Posted October 13, 2021 I would say run for a while and then check your plugs for a lean running condition. Another indicator of insufficient back pressure is backfiring at deceleration. So as long as your plugs do not show a lean running condition and you do not have a lot of backfiring you should be fine. If you do find your running too lean and are backfiring a lot on deceleration there is the risk of burning valves. Link to comment Share on other sites More sharing options...
