BigBear Posted July 16, 2010 Share #1 Posted July 16, 2010 I just replaced my brakes (F&R) with EBC Sintered HH pads. I cleaned both front rotors with brake cleaner and install the pads. After 200 miles, the brakes didn't seem to "grab" enough...brake lever is solid (didn;t monkey with the brake fluid). Took them off, cleaned the rotors and brake pads with brake cleaner...get much better braking capacity, but now I get almost a metal-on-metal sound when I apply the front brakes. Any ideas or thoughts? I've seen folks here have sanded thier rotors and scuffed up their pads with sandpaper. That scraping sound is getting annoying... Link to comment Share on other sites More sharing options...
dingy Posted July 16, 2010 Share #2 Posted July 16, 2010 Don't take this as an insult to your mechanical abilities. Did you by any chance put a pad in backwards? Gary Link to comment Share on other sites More sharing options...
Oldslow Posted July 16, 2010 Share #3 Posted July 16, 2010 Mine were making that scraping sound.Took them off and filed edges as per instruction from this site. Still makes that sound...I just ignore it now! Link to comment Share on other sites More sharing options...
rod Posted July 16, 2010 Share #4 Posted July 16, 2010 Make sure your pistons are clean and put some brake pad grease on the back of the pads. Good luck Rod Link to comment Share on other sites More sharing options...
BigBear Posted July 16, 2010 Author Share #5 Posted July 16, 2010 Dingy - No insult taken....but can you really put them in backwards? Great suggestion - Chamfering the edges of the pads is my next attempt! BTW: I sprayed the backs of the pads with CRC "disc Brake Quiet" prior to assembly? Rod - When you say clean the pistons, do mean the outside of the piston or the top of the piston that seats to the BACK () of the pad? If these tricks don't work, I'll just turn up the tunes! Thanks for the inputs guys! Link to comment Share on other sites More sharing options...
rod Posted July 16, 2010 Share #6 Posted July 16, 2010 Rod - When you say clean the pistons, do mean the outside of the piston or the top of the piston that seats to the BACK () of the pad? Both actualy, make sure everything is smooth with no ruff spots and lube the back of the pad. Rod Link to comment Share on other sites More sharing options...
saddlebum Posted July 16, 2010 Share #7 Posted July 16, 2010 Sometimes that can be caused by metalic or ceramic linings. Both CRC and PERMATEX make a product called disc brake quiet (I prefer the paste version over the spray). Remove the pads and coat the back side of the pads. allow time for the product to get semi dry or tacky and then reinstal the pads. I use it on almost every brake job I do from motorcycles to heavy trucks. Link to comment Share on other sites More sharing options...
Sailor Posted July 16, 2010 Share #8 Posted July 16, 2010 If it is dusty there where you are you will get that noise. I have a fairly long gravel driveway and get that noise all the time. Link to comment Share on other sites More sharing options...
royalstarjac Posted July 16, 2010 Share #9 Posted July 16, 2010 Dingy - No insult taken....but can you really put them in backwards? Great suggestion - Chamfering the edges of the pads is my next attempt! BTW: I sprayed the backs of the pads with CRC "disc Brake Quiet" prior to assembly? Rod - When you say clean the pistons, do mean the outside of the piston or the top of the piston that seats to the BACK () of the pad? If these tricks don't work, I'll just turn up the tunes! Thanks for the inputs guys! Yes you can put them in backwards. It's easy to do if you're not paying attention. Don't ask me how I know. Link to comment Share on other sites More sharing options...
GeorgeS Posted July 16, 2010 Share #10 Posted July 16, 2010 As above-- Any auto parts store, get some disk brake adhisive, its cheap, simply pull out the pads and apply the stuff. I have had the same problem, the stuff works, problem solved. Link to comment Share on other sites More sharing options...
SilvrT Posted July 16, 2010 Share #11 Posted July 16, 2010 Sometimes that can be caused by metalic or ceramic linings. Both CRC and PERMATEX make a product called disc brake quiet (I prefer the paste version over the spray). Remove the pads and coat the back side of the pads. allow time for the product to get semi dry or tacky and then reinstal the pads. I use it on almost every brake job I do from motorcycles to heavy trucks. What he said. Coat all areas where there is metal contact and make sure the slider pins are lubed. Also, don't use regular sandpaper on the pads or rotors... use emery paper. (don't ask me why ... it's just what I was taught in mechanics school some 45 years ago) Link to comment Share on other sites More sharing options...
