RickyP Posted November 25, 2018 Share #26 Posted November 25, 2018 I've done it to my Roadstar I had and my Venture. I like a little sound, but didn't like the loud sound my Vance and Hines were putting out. I do like the sound coming out of my Venture now, not to loud, but not to soft. I drilled 1/2 inch holes at 12-3-6 and 9 looking at the pipe from the rear. Bob Where did you find Vance and Hines or did you have to make them fit? Link to comment Share on other sites More sharing options...
YamahaLarry Posted November 26, 2018 Share #27 Posted November 26, 2018 I recently installed RK mufflers on my 09 RSV. They are a VERY tight fit. I did purchase the wide clamps from the local HD dealer, but got the pipes for free. As for the mounting brackets, you can make them yourself for well under $20 by purchasing 2 ea 2" x 12" plates from Lowes, Tractor Supply, etc. It will require 3 holes drilled in the plate and cut it off to 11" long. Some say you need 1/4" plate, but that is way overkill. I used a 1/8" plate (HR steel) and it's very rigid. You can find the locations for the holes by using Google. Link to comment Share on other sites More sharing options...
