GeorgeS Posted October 24, 2007 Share #1 Posted October 24, 2007 I just found this web site. Lots of information the basic operation of carburators, if anybody is interested. I was looking for info on setting float levels, when I just found the site. http://hondanighthawks.net/carbhelp.htm? Link to comment Share on other sites More sharing options...
Squeeze Posted October 24, 2007 Share #2 Posted October 24, 2007 I just found this web site. Lots of information the basic operation of carburators, if anybody is interested. I was looking for info on setting float levels, when I just found the site. http://hondanighthawks.net/carbhelp.htm? Hi George, thanks for the Link. As for the Float Level in the 1Gen Carbs. I've done the Carbs of my Max last Week. On similiar measuring Process like the 2Gen. Procedure, i tested and stipulated the Float Levels at 37 mm. Of course, the Max has different Carbs, but the Casings and everything else is the same on the 1Gen BDST34 Mikuni's. I tested the Valves in a clear Bowl with a Hose on the Fuel intake and blowed Air into the Hose until the Valve did close. Then measured the Distance, adjusted the next Carb and checked the closing of the Float Valve. Worked fine. So, all you need is to download the 2Gen Manual from the Archive here, adjust the Tab of the Floater to 37 mm instead of the 2Gens 28 mm and be done with it. Link to comment Share on other sites More sharing options...
