Case522 Posted May 6, 2010 Share #1 Posted May 6, 2010 Ive got a 1984 1300 voyager that is having overheat problems. Ive flushed the system, replaced the thermostat. any help will be greatly appreaceted. Link to comment Share on other sites More sharing options...
Monty Posted May 6, 2010 Share #2 Posted May 6, 2010 Sup Woody? Glad to see you on here. Have you inspected the water pump impeller? Are you sure it's circulating? Is the timing right? Is the fan turning the right direction? There are sooo many things that could cause it. If I get time, I could help you try to track it down. All you need to do is buy the beer. Link to comment Share on other sites More sharing options...
mabeline Posted May 7, 2010 Share #3 Posted May 7, 2010 Have you tried washing the bugs and road grim out of the rad core? Link to comment Share on other sites More sharing options...
wwdsnipes Posted August 6, 2012 Share #4 Posted August 6, 2012 Did you ever get your overheating problem fixed? I have the same problem Link to comment Share on other sites More sharing options...
