BigBoyinMS Posted February 23, 2010 Share #1 Posted February 23, 2010 Every now and then someone asks what size a particular bolt is. Just thought it would be helpful to post this from another site. FYI, you can get the part# from most Yamaha dealer websites or here. "How to get sizes of bolts from the part numbers... The Yamaha microfiche shows the bolt size, you just have to know how to read it. Here is how it works... The part number is broken down into 3 parts 99999-06012-00 is an example. The second part, which is 06012 tells you the size. That bolt is 6mm in diameter and 12mm in length. If the second part was 08024 the bolt would be 8mm in diameter and 24mm in length. The first part of the part number tell what type of part it is such as bolt, screw, washer etc. and last 2 digits generally determines the finish such as black, cad, etc" Link to comment Share on other sites More sharing options...
Guest human4m Posted February 23, 2010 Share #2 Posted February 23, 2010 Outstanding bit of info! That will come in handy when dodging the parts counter! Link to comment Share on other sites More sharing options...
LilBeaver Posted February 23, 2010 Share #3 Posted February 23, 2010 Wow, this is terrific!! I wish I would have known this a long time ago. I have spent more than enough time using the guess and check method on some of these. I guess now I have a fair assortment of bolts... Thanks for the info!! Link to comment Share on other sites More sharing options...
BuddyRich Posted February 24, 2010 Share #4 Posted February 24, 2010 Is there somewhere in that part number it shows the pitch of the thread ? Link to comment Share on other sites More sharing options...
Squeeze Posted February 24, 2010 Share #5 Posted February 24, 2010 Is there somewhere in that part number it shows the pitch of the thread ? Not that i know of. But Yammi does not use fine Threads in M6 or M8, at least i haven't stumbled upon one so far. If so, be assured the Bolt is a special Shape and can't be replaced with a standard shape metric Bolt easily. On the other Hand they have a Faible for M10x1.25 Threads. Lots of M10 Bolts are this fine Pitch, but not all of them. The only other Bolt i know of, which is fine Thread is the long right Side rear M10 Engine Bolt on 1Gen Vmax. This is M10x1.0. Doesn't make any Sense to me, but you know these Enigineers are special sometimes... Link to comment Share on other sites More sharing options...
BuddyRich Posted February 24, 2010 Share #6 Posted February 24, 2010 Doesn't make any Sense to me, but you know these Enigineers are special sometimes... :rotf: I heard that. Link to comment Share on other sites More sharing options...
Rick Oshea Posted February 2, 2021 Share #7 Posted February 2, 2021 Do you know the thread and pitch of the yamaha nut part # 95612-16100-00 Link to comment Share on other sites More sharing options...
Marcarl Posted February 2, 2021 Share #8 Posted February 2, 2021 7 minutes ago, Rick Oshea said: Do you know the thread and pitch of the yamaha nut part # 95612-16100-00 Maybe best post this in a new thread, it will get more attention and replies. And welcome to Venture Riders. Link to comment Share on other sites More sharing options...
Pro procrastinator Posted February 2, 2021 Share #9 Posted February 2, 2021 Take that part number to any yam dealer. its used in a couple quads Link to comment Share on other sites More sharing options...
saddlebum Posted February 2, 2021 Share #10 Posted February 2, 2021 (edited) On 2/24/2010 at 4:01 PM, Squeeze said: Not that i know of. But Yammi does not use fine Threads in M6 or M8, at least i haven't stumbled upon one so far. If so, be assured the Bolt is a special Shape and can't be replaced with a standard shape metric Bolt easily. On the other Hand they have a Faible for M10x1.25 Threads. Lots of M10 Bolts are this fine Pitch, but not all of them. The only other Bolt i know of, which is fine Thread is the long right Side rear M10 Engine Bolt on 1Gen Vmax. This is M10x1.0. Doesn't make any Sense to me, but you know these Enigineers are special sometimes... Its very simple really, M10x1.25 means its a 10mm diameter bolt and the 1.25 is the millimeters between two threads from peak to peak. There for a bolt M10x1.0 is a finer thread than M10x1.25 or M10x1.5 which is even a courser Thread. where as SAE indicates the number of threads per inch. So in metric the lower the second number the finer the were with SAE bolts the higher the number the finer the thread. The nice thing about metric bolts you can actually use a pair of calipers to measure the diameter and length of the bolt as well as the distance between two threads to tell you exactly what bolt you need. Edited February 2, 2021 by saddlebum Link to comment Share on other sites More sharing options...
cimmer Posted February 3, 2021 Share #11 Posted February 3, 2021 This was posted along time ago so i will repost it here. This is not my work but a copy of someone else and unfortunately I don't remember who that was Hope this helps you out as it has for me before.. Rick F Thought this part number decoder might be useful.docx Link to comment Share on other sites More sharing options...
Pro procrastinator Posted February 3, 2021 Share #12 Posted February 3, 2021 After looking online im surprised at how many parts are currently out of stock! But am i correct in thinking that the nut rick is looking for is a iso 16 mm selflocking? Link to comment Share on other sites More sharing options...
