Files Updated on 10/28/2009:p>:p>
All Audio circuits now on main page, so that all schematics are now just one page.
Other minor corrections done to all schematics.
Text realigned for easier reading
Some Line types changed for easier reading.
Gary
I have completed the 1st Generation schematics. My goal in doing this is to make them easier to read and reduce the number of pages needed to display the information. I have used color and line types to make the wiring easier to follow. In some cases I could not use the exact color that is being represented due to visibility and printing issues. For example yellow is hard to see on the screen and does not print well.
The previous posting for the 1983-1985 models have been replaced by what is included with this post.
The 1983 differs significantly from the 1984-1985 models in the areas of Flasher, Hazard, Starting Circuit Cut-Out Relays, the Hazard Switch, Canceling Unit & Diode Pack.
The files for the 86-89 models that were previously posted have been revised slightly and are now at Revision B. Major corrections done included coils were numbered incorrectly in Simplified Circuit & the Flasher Relay Assembly has been updated to include flasher information.
The 1990 major changes from the 1986-1989 models were the TCI, coil pick-up & fuel pump control.
This post supersedes all previous posts I have done in regards to the 1st gen wiring diagrams. All 1st gen's are included in this post.
The files will look best when plotted at 11" x 17" size or larger. Office Max and Staples as well as others can do this for you for a minimal charge if you want a printout. I paid $1.00 for an 11" x 17" color print at Staples.
83 Yamaha Venture TK Wiring Diagram Rev C.pdf
1983 Venture XVZ12TK
From 1983 Yamaha Venture Owners Manual.
83 Yamaha Venture Royale TDK Wiring Diagram Rev C.pdf
1983 Venture RoyaleXVZ12TDK
From 1983-1985 Yamaha Venture Service Manual
83 Yamaha Venture TK Simplified Circuit Diagram Rev C.pdf
From 1983-1985 Yamaha Venture Service Manual, page 7-1
83 Yamaha Venture Royale TDK Simplified Circuit Diagram Rev C.pdf
1983 Venture Royale XVZ12TDK
83 Yamaha Venture electrical info.pdf
This file is a compilation of various sheets from the 1983 Yamaha Venture Service Manual that would be helpful when working with electrical system. They are not modified in any way, just as they appear in service manual.
84-85 Yamaha Venture L Wiring Diagram Rev C.pdf
1984-1985 Venture XVZ12L
84-85 Yamaha Venture Royale DL Wiring Diagram Rev C.pdf
1984-1985 Venture Royale XVZ12DL
84-85 Yamaha Venture L Simplified Circuit Diagram Rev C.pdf
84-85 Yamaha Venture Royale DL Simplified Circuit Diagram Rev C.pdf
1984-1985 Venture XVZ12DL
84-85 Yamaha Venture electrical info.pdf
This file is a compilation of various sheets from the 1983-1985 Yamaha Venture Service Manual that would be helpful when working with electrical system. They are not modified in any way, just as they appear in service manual.
86-87 Yamaha Venture DS Wiring Diagram Rev D.pdf
1986-1987 Venture XVZ13DS/DSC
From 1986-1993 Yamaha Venture Service Manual, page 8-41. PDF file pages #467 & 468 of 496.
88-89 Yamaha Venture U Wiring Diagram Rev D.pdf
1988-1989 Venture XVZ13U/UC
From 1986-1993 Yamaha Venture Service Manual, 1988-1989 Supplement. PDF file page #478 of 496.
88-89 Yamaha Venture DU Wiring Diagram Rev D.pdf
1988-1989 Venture XVZ13DU/DUC
From 1986-1993 Yamaha Venture Service Manual, 1988-1989 Supplement. PDF file pages #477 & 479 of 496.
86-89 Yamaha Venture Simplified Circuit Diagram Rev D.pdf
1986-1989 Venture XVZ13DS/DSC - U/UC - DU/DUC
From 1986-1993 Yamaha Venture Service Manual, page 7-1 thru 7-4. PDF file page #265 thru 268 of 496.
90-93 Yamaha Venture DA Wiring Diagram Rev C.pdf
1990-1993 Venture XVZ13DA/DAC
From 1986-1993 Yamaha Venture Service Manual, 1990-1993 Supplement. PDF file pages #495 of 496.
90-93 Yamaha Venture DA Simplified Circuit Diagram Rev C.pdf
From 1986-1993 Yamaha Venture Service Manual, 1990-1993 Supplement. PDF file pages #492 of 496
86-93 Yamaha Venture electrical info.pdf
This file is a compilation of various sheets from the 1986-1993 Yamaha Venture Service Manual that would be helpful when working with electrical system. They are not modified in any way, just as they appear in service manual.
Edited by dingy
files updated 10/28/09
Link to post
Ahh Geesh Dingy........You made my day. I feel a lot better knowing I'm not the only one that don't get out enough. LOL!
I got to say that is a lot of work to convert this info. I'm sure it will be a great help for some of us that need a little extra coaching when it comes to rubber coated copper thingies.
From me.......thanks a bunch!
Mike
Link to post
Would anyone want something like this done for the RSV's.
Anyone have any idea how many versions there would be?
Until I find a real Job, this keeps me active and productive. Pay sucks.:scorched:
Gary
Link to post
Gary
I would LOVE to have it for the RSV. One version should cover all the years.
Link to post
Yea, were ALL running the SAME cassette player.........1999-2010....:rotfl:
They do look nice though. I would consider one for the 2nd gen, as much as my electrical system has bugged me....
Link to post
  • 2 weeks later...
I have updated the schematics to help make them easier to read.
All files are now on one sheet.
I have eliminated the Audio sheet as Sheet #2, all Audio circuits are now shown on main page.
I have staggered the wire color call outs where they are clustered together, such as by the instrument cluster connector.
I removed the line types that had the X's & O's in them. These made it look like wires that crossed were connected in some places.
I have added a legend to all sheets to help some people understand schematics a little better.
Showed springs in the switches on simplified circuits to help clarify operation of switch.
Only wiring change made was that the Emergency Stop Sensor was incorrectly shown as closed, it is now shown as an open contact.
RSv version changed slightly as well.
Hopefully this will be last change to them, I probably have a lot more than a couple hundred hours creating all of these. There are 16 different versions.
Gary
Link to post
  • 6 years later...
Super old post, but just wanted to say thanks to Gary.
I'm installing a new harness and COP. All the OEM diagrams give you the wire colors but not the cylinder positions for the coils. At least, none of the info I have available to me do. They list colors but coils are just listed 1~4 without showing which is which.
Yamaha's nice little wraps of tap with the cyl numbers were also long gone.
My cheese was just about to slip off my cracker until I saw Gary's diagrams actually break it into 1-Orange, 2-Gray, 3-Yellow, 4-White.
Edited by Great White
Link to post
Coincidentally, just yesterday, I found that there is a minor mistake in the Yamaha wiring diagram (and in Dingy's schematic). Yamaha shows the wire color from the connector to the coil to be either gray, orange, yellow or white along with the common red/white wire. In fact, the wire color from the coil connector to the coil is orange (along with the red/white) on all coils.
Edited by Prairiehammer
Link to post
[ATTACH=CONFIG]104112[/ATTACH][ATTACH=CONFIG]104113[/ATTACH][ATTACH=CONFIG]104114[/ATTACH]
I noticed that too. But since I was dumping the OEM coils for COP, I didn't worry about it.
I suppose it could trip someone up in the future though. while the wiring harness is too short to mix up left and right, a determined individual probably could mix up 1 and 2 or 3 and 4.....
Link to post
  • 4 years later...
Gary
I love you!!
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
