mattevans Posted May 11, 2009 Share #1 Posted May 11, 2009 I have recently installed a new clutch, I am having a problem when starting the bike sometimes. It seems if the bike is in gear and i pull the clutch lever to start. The bike moves forward, as the starter turns over as if the clutch is not disengsging the trans completely. I had this problem prior to the new clutch. Has anyone encountered this:think: Link to comment Share on other sites More sharing options...
mother Posted May 11, 2009 Share #2 Posted May 11, 2009 i would first try and bleed the clutch line. if there is air in the line, this may be causing the clutch to not disengage fully. let us know how you make out. cheers, Scott Link to comment Share on other sites More sharing options...
