CAZCO Posted April 6, 2009 Share #1 Posted April 6, 2009 Has anyone ever tested their starter button ONCE you get to it? Can't find anything online about how to do it. Thankx Gary C Link to comment Share on other sites More sharing options...
CAZCO Posted April 6, 2009 Author Share #2 Posted April 6, 2009 Sorry, it is an '89 1st Gen Link to comment Share on other sites More sharing options...
Monty Posted April 7, 2009 Share #3 Posted April 7, 2009 (edited) Does it only have two wires? You can use a multimeter, and set it on "ohms". Touch the leads together first(without touching the metal leads with your hands), and make sure you get continuity(0 ohms). That verifies the meter is working and that the leads are good. Now, attach a lead to each wire. Meter should say OL or infinity, or something like that. Now, push the button with the leads attached, and the meter should read the same as when you shorted the leads together before(0 ohms). I don't have a schematic for your model to look at, but it should just be a simple two wires. That's how it is in the '83-'85 manual. Edited April 7, 2009 by Monty Link to comment Share on other sites More sharing options...
5bikes Posted April 7, 2009 Share #4 Posted April 7, 2009 The starter button activates the starter solenoid and turns the lights OFF when pushed. There is way too much current for these tiny contacts in my opinion. They are exposed to weather and dirt. Use contact cleaner or brake cleaner to periodically clean them. They can be carefully disassembled and the contacts cleaned with fine sandpaper for a longer lasting fix. Dielectric grease helps too. I took my lights out of this circuit and this switch only runs a DPDT relay coil for all the lights. Link to comment Share on other sites More sharing options...
CAZCO Posted April 8, 2009 Author Share #5 Posted April 8, 2009 Yes, mine is 4 wire. Want to pull the lites off this feed but will do later. Thanks again for the advice! Gary C Link to comment Share on other sites More sharing options...
