Yammer Dan Posted December 11, 2008 Share #1 Posted December 11, 2008 If you must store a Scoot try to go past it once in a while (as often as possible) and work the clutch lever and the brake levers a few times. It is best to start them as often as possible but if you can't work those levers and save yourself a lot of trouble when you get them back out. Just take a few seconds to stop and pump them a few times. Link to comment Share on other sites More sharing options...
BoomerCPO Posted December 11, 2008 Share #2 Posted December 11, 2008 No need to do that with 2nd Gens....They are always on the road! Link to comment Share on other sites More sharing options...
dynodon Posted December 11, 2008 Share #3 Posted December 11, 2008 I would just add that starting the engine once in a while is normally NOT a good idea unless you can get it out and really get it hot. Just starting up and letting it run a few seconds, or even a couple minutes, will just create moisture in the crankcase and exhaust, you won't get it hot enough to burn that off. So unless you can get it on the road for 15-20 minutes at least, don't mess with it. pulling on the clutch and brake levers and pedal though, that won't hurt anything, and I can see the logic and keeping them from settling too much. Link to comment Share on other sites More sharing options...
BradT Posted December 12, 2008 Share #4 Posted December 12, 2008 I always turn off the fuel and run the carbs dry, then pull the battery and keep it charged. Park it on rubber mat and cover it up. Stays like that untill April Brad Link to comment Share on other sites More sharing options...
Yammer Dan Posted December 12, 2008 Author Share #5 Posted December 12, 2008 Right if you do get to start it at least make sure you run it til it gets to operating temps for a while. I never shut fuel off on my ventures Brad. With the weather here you never know when you are get a day you want to fire it up and maybe take a "little" ride. A caliper not used can stick pretty quick and working those levers prevents that. Link to comment Share on other sites More sharing options...
BradT Posted December 12, 2008 Share #6 Posted December 12, 2008 Right if you do get to start it at least make sure you run it til it gets to operating temps for a while. I never shut fuel off on my ventures Brad. With the weather here you never know when you are get a day you want to fire it up and maybe take a "little" ride. A caliper not used can stick pretty quick and working those levers prevents that. Not going to be able to go for a ride till at least March (even then we would be lucky). Most likely take you up on your suggestion of moving the levers once in a while. They will be 10 years old soon. Thanks, Now I just have to Remember to do it Brad Link to comment Share on other sites More sharing options...
