Rottdoglover Posted October 28, 2008 Share #1 Posted October 28, 2008 I just bought a 88 Venture. Love it but the air ride does not work and the display shows NOTHING. Pulled the white plug and checked all conections No voltage anywhere. Any ideas. Also, has anyone ever relaced the CLASS with manual gauges and switches? May sound lo-tech but Po' boys got lo-bucks. Thanks Link to comment Share on other sites More sharing options...
93 venture Posted October 28, 2008 Share #2 Posted October 28, 2008 Did you check for power with the key switch in the acc. positions? only time it has power to the Class,also the fuse box is a weak point on these bikes,the glass fuse holders will get weak and wont hold the fuse tight enought to make contact. Dont give up on it,lots of cheap parts on ebay for this bike. Link to comment Share on other sites More sharing options...
sarges46 Posted October 28, 2008 Share #3 Posted October 28, 2008 There is also a fix for the error codes that may spring up. It's in the 1st gen tech library and easy to do. Link to comment Share on other sites More sharing options...
mbrood Posted October 28, 2008 Share #4 Posted October 28, 2008 Although it only works in the ACC key position, isn't the fuse a blade type in a small box in front of the battery? Link to comment Share on other sites More sharing options...
GeorgeS Posted October 28, 2008 Share #5 Posted October 28, 2008 Fuse, for CLASS system, is a Seperate Fuse Holder. You have 5 fuse's on top of the Battery. ( glass type fuse's ) " ACC " " Head " "Ignition " " Signal " " Tail " You have a second fuse holder unit, located forward, and a little right of the Battery, which has. ( 4 ATM type fuses inside. ) " Back - up" ( for the audio system) " Audio, CB " " Fan " " Hazard " The Class Fuse Holder, is a Seperate Unit, with just One fuse inside ( wires going into and out of this holder, are Red/Blue Link to comment Share on other sites More sharing options...
Rottdoglover Posted October 28, 2008 Author Share #6 Posted October 28, 2008 A big thanks for the info and help. Found the seperate fuse and while pulling it out found a bad connection. Fixed it and voila, I have air ride that WORKS!!! Thanks again. Link to comment Share on other sites More sharing options...
Captainkirk Posted November 1, 2008 Share #7 Posted November 1, 2008 Glad you got it working! If it begins giving you error codes (it well may), this link in the tech section is a fantastic write up. It worked miracles on the CLASS unit I was working on, and wasn't that hard to to. Store it in your files; you may need it some day. http://www.venturerider.org/forum/showthread.php?t=493 Link to comment Share on other sites More sharing options...
lvsloan1 Posted August 22, 2013 Share #8 Posted August 22, 2013 We have a Venture Royale that has a Motortrike conversion. When we bought it, it was still wired for the class to operate ONLY in the "ACC" key position. This is so you can't air the shocks while riding as the owners manual says to have NO weight on the bike when doing this. Since ours is triked w/ rear air bags, we wanted to monitor & adjust air pressure while going down the road like the Goldwing trikes do. So I hooked a wire to the input of the class fuse from the accessory positive terminal in the fuse box on top of the battery. Now we can monitor and control the air system while riding. Link to comment Share on other sites More sharing options...
cabreco Posted August 28, 2013 Share #9 Posted August 28, 2013 Spent 20 minutes today following the E4 error, CLASS fix write up. Pretty simple fix, works like a dream. Funny though, the solders didn't look bad enough to be a connectvity issue. Anyway, Thanks to the writer & all of you who pointed me to it! Link to comment Share on other sites More sharing options...
