User Tag List
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: tag along harbor freight
  1. #1
    Join Date
    May 2012
    Muscatine, IA
    IA
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default tag along harbor freight
    well when you buy this trailer. There not supposed to charge you tax. You pay the tax when you get the plates. Didn't go that way with me. so just a heads up for next guy. Also if you don't show them the discount price they will try to charge you full price. So be ready or they will try and jip ya. Was going to buy a lift from them but don't know now. Don't like that stuff from stores I'm the customer not the victim.
    rodney swailes
  2. #2
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    285 Post(s)
    Tagged
    0 Thread(s)
    Default
    I guess that will vary by locality.
    In Wisconsin you do have to pay the tax at the store because the GVW of the trailer is under 3,000 lbs so no registration or plates required.
    If you take that state paperwork back to the HF store and talk nice, you can probably get the tax refunded to you.
    Jeff Borowski . . Had 88 Venture standard, now 2011 Silverado 4x4
    There are 10 kinds of people that understand binary, those that do, and those that don't.
    Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
  3. #3
    Join Date
    May 2012
    Muscatine, IA
    IA
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default
    lol I store this trailer inside. Went to move it today. Right wheel wont hardly move. Don't know if plastic cone broke on bearing or what. I might have about 1300 miles on it and I did grease it. Just through the grease fitting though. Just thought it was funny { locked up in a garage out of weather. } will have to fix as its in the way. Thought I would use it more but that never happened. Also the little black latches fall off when released. turd
    rodney swailes
  4. #4
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    15 Post(s)
    Tagged
    0 Thread(s)
    Default
    Guess that varies by state. Fla you would pay sales tax, then buy tags. As far as I know.
    2013 Black Victory XCT
    Trailers are for when your bike is broke, aint they?
  5. #5
    Join Date
    Nov 2011
    Tucson
    AZ
    Post Thanks / Like
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have found that the bearings on the HF trailers are junk even keeping them greased. I lost the bearings on my 4X8 in the mountains in the middle of a rain storm. I replaced them with real bearings and have not had a problem since.
    I know the voices aren't real... But they do have some really great ideas !
    The problem isn't the problem. The problem is your attitude about the problem. Capt Jack Sparrow
  6. #6
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    285 Post(s)
    Tagged
    0 Thread(s)
    Default
    I still want to build a new axle for my HF trailer. It will then use standard bearings and seals available everywhere, and it will have electric brakes.
  7. #7
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    15 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Flyinfool View Post
    Then you would have to figure out a way to add a brake controller also like in a truck wouldnt you? Good idea I think as these things dont stop all that well anyways.
  8. #8
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    285 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yes it will need a controller.
    I found a brake controller that I could mount on the trailer tongue in a water proof box. It has a wireless remote that I can put on the handle bars. This way I do not have to have the controller on the bike all the time when I am not using the trailer. Most of my riding is without the trailer. Brake controllers have a 4 wire hookup, power, ground, brake lights, and wire to the brakes. Power I can get from the running lights since they are on anytime the bike is running, Ground is obvious, brake light I can tap off of my high center brake light. Technically if you have trailer brakes you are supposed to have a breakaway switch (or device if you have surge brakes) and a battery on the trailer so that if the trailer ever comes off the hitch and the safety chains do not hold, it will lock the trailers brakes. I have not decided if I will do that or not. I may since I normally pack a battery for powering stuff in the tent. Having the battery wired in, it will be charging while traveling.
  9. #9
    Join Date
    Nov 2011
    Tucson
    AZ
    Post Thanks / Like
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    Default
    I presume in order to do all that you have upgraded the stater/charging system on your bike ? I think that is my next upgrade to my 89. Not to hijack the thread, but on a scale of 1-10, how hard is it to upgrade the stator/charging system ?
  10. #10
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    285 Post(s)
    Tagged
    0 Thread(s)
    Default
    I went the other way. I replaced every bulb on the bike and trailer with LED, The stock system now has plenty of spare power. With everything on the bike turned on it is still charging at idle. The electric brakes take less power that the Electric Anti Dive on the bike. so if you have gone progressive springs and unplugged the EAD, there is the power that the brakes need.
    How is that for swinging a hijack back on track?
  11. Likes videoarizona liked this post
  12. #11
    Join Date
    Nov 2011
    Tucson
    AZ
    Post Thanks / Like
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    Default
    Rabbit trail........
    Back off track...
    So how much do you think it cost to switch everything over to LED's ? I have disconnected my anti-dives ( which a BIG difference) but I also have a lot of lights..in fact I just finished adding the OEM trunk guard on mine, although I wired the four rear lights to the brakes and the four side lights are brake/turn signals, there is a total of 26 additional lights on the rear not counting the stock rear light. I know I read something about converting to LED in the past, but doesn't it take adding something to make the LED's work in place of the stock ? Do they just plug in the same as the stock ? Inquiring minds want to know ??
    Click image for larger version.
Name:	Rear lights.JPG
  13. #12
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    285 Post(s)
    Tagged
    0 Thread(s)
    Default
  14. #13
    Join Date
    Nov 2011
    Tucson
    AZ
    Post Thanks / Like
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    Default
    OKAY, you totally lost me on the wiring, resistors, boards, wiring, resistors, PCB's, horn flashers, resistors.... etc..etc..etc..
    I guess I'll look into upgrading the stator which should be more in line with my abilities.
  15. #14
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    127 Post(s)
    Tagged
    0 Thread(s)
    Default
    Bill,
    You can convert your running lights to LED without any issues or resistors. Resistors are only needed on the turn signal circuit because the turn signal flasher needs the resistance of the light bulbs (the load on the circuit) to flash at the proper speed. Without normal bulbs in that circuit, the flashers flash to fast...requiring the addition of resistors to slow everything down again. To me, adding resistors to the circuit is a waste since they have the same current draw as the light bulbs...so no gain there.
    However, if you add LED turn signals to your existing bulb turn signals, no resister needed since the bulbs are still in line with the flasher. That's what I did when I replaced my front and rear side reflectors with LED lights and attached them to the running light circuit and the turn signal circuit. They run all the time and blink when I use turn signals.
    Bottom line:
    1: Adding LEDs to your existing turn signals is fine...no resistors needed.
    2: Replacing your bulb running lights with LED's is fine as well. No resistors needed.
    By switching out all your bulb running lights with LED's, your electrical load will drop a lot.
    Last...there are LED replacement bulbs on the market that simply plug in to your run/brake light in the rear. That results in a brighter light that uses less power.
    Fool's little circuit board will add a flasher to that system so his brake lights will flash when applied. We can buy those flashers for incandescent and LED bulbs as well...he is saving bux and getting exactly what he wants by building it himself! Cool...
    Hope this helps,
    david
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
    "Some mistakes are too much fun to only make once." - Well worn saying
    "Great ideas often receive violent opposition from mediocre minds." Albert Einstein
  16. #15
    Join Date
    Jun 2009
    Saanichton, BC
    Canada
    BC
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by KIC View Post
    While sorting out changing to all LED's begin by converting the guard lights to LED's which will reduce the load and not require the addition of a turn signal resistor.
Similar Threads
  1. Harbor Freight Lift $200 off
    By dingy in forum Watering Hole
    Last Post: 11-03-2011, 01:57 PM
  2. Harbor Freight
    By scarylarry in forum Watering Hole
    Last Post: 02-09-2011, 04:58 PM
  3. new harbor freight tag-a-long
    By dray in forum Trailer Talk
    Last Post: 01-25-2011, 07:31 PM
  4. 25% harbor freight
    By MidlifeVenture in forum Watering Hole
    Last Post: 11-26-2010, 10:34 AM
  5. Harbor Freight
    By Brake Pad in forum Trailer Talk
    Last Post: 04-21-2009, 12:05 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
