lift adapter help...
midnightrider1300
Line it up, slide the rod thru... done.
Make sure when you lift it...that the pads on the lift are all the way against the stop on the left side of the bike.
What issue are you having with putting it on the bike?
maybe i just need to look and make sure which way it goes...got it late yesterday, only fooled with bout 10 minutes this morning b4 heading to work...lol i may need a PICTURES .lol :whistling::whistling::confused:
  • 3 weeks later...
From Carbon-One classified -
(The original Carbon_One lift adapter attaches to the bottom of either a "05" - "09" RSTD or a "99" - present RSV. Using this adapter allows one to use any atv/mc jack to lift your bike safely. Made of solid steel you'll have years of use for as long as you own your bike.
Some Larin and Harbor Freight jacks have short lift arms (12") so if you have one of these I add a safety bar to the adapter. Do make a note in any order if this feature is required. My adapters are 12 1/2" wide so any jack with 13" lift arms or longer can be used easily. )
I just bought one and quality made- would recommend it. Just look in member classified section for info on it.
