Eck Posted August 31, 2014 Share #1 Posted August 31, 2014 If you locked your key and remote keyless fob inside your trunk on a Honda Goldwing 1800, and you don’t have a spare key, here is a trick or a work around to help you out in this situation. This works like a charm but you will need two things. 1) -The allen wrench to take of the passenger grips off the seat so you can remove the seat. 2) - You will also need a 2ft long 14 / 16 gage wire for jumping the connection. Instructions: 1) remove seat 2) connect a wire to the "positive" on the battery terminal 3) under seat, find the GREY 14 pin connector - (on side without battery towards the back) 4) insert (just touch) the other end of the wire in the back of the connector to the "BLUE" wire 5) IT UNLOCKS note: Leave the GREY 14 pin connector CONNECTED - do not disconnect the connector as it needs to be connected to complete circuit. You should learn from this to ensure you carry or hide a spare key on your motorcycle just in case! Here is a photo of the GREY 14 PIN connector with instructions. Link to comment Share on other sites More sharing options...
bongobobny Posted August 31, 2014 Share #2 Posted August 31, 2014 And we learned this because??? Link to comment Share on other sites More sharing options...
BuckShot Posted August 31, 2014 Share #3 Posted August 31, 2014 And we learned this because??? So we all know how to help Eck out if he pulls a boo boo..... Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 31, 2014 Share #4 Posted August 31, 2014 One of these will work also! Link to comment Share on other sites More sharing options...
Brake Pad Posted August 31, 2014 Share #5 Posted August 31, 2014 My spare key is attached the the battery box, never an issue:twing: Link to comment Share on other sites More sharing options...
SilvrT Posted August 31, 2014 Share #6 Posted August 31, 2014 Never lock your trunk and you'll never need this very useful TIP. - OR - Don't buy a Goldwing Link to comment Share on other sites More sharing options...
Yammer Dan Posted August 31, 2014 Share #7 Posted August 31, 2014 Never lock your trunk and you'll never need this very useful TIP. - OR - Don't buy a Goldwing PROBLEM SOLVED!!!:rotfl: Link to comment Share on other sites More sharing options...
Flyinfool Posted August 31, 2014 Share #8 Posted August 31, 2014 Never lock your trunk and you'll never need this very useful TIP. - OR - Don't buy a Goldwing Another reason Yamaha is better. You need to use the key to lock the trunk. It is nearly impossible to lock the key in the trunk. If you are creative you can accomplish it. Link to comment Share on other sites More sharing options...
BoomerCPO Posted August 31, 2014 Share #9 Posted August 31, 2014 I don't own a Goldwing...but if I did....I'd stash a pygmie in de trunk fer situations like dis.... Boomer....who sez offering dat pygmie a shot of tequila will have him popping dat trunk open in nothing flat.... Link to comment Share on other sites More sharing options...
Condor Posted August 31, 2014 Share #10 Posted August 31, 2014 I don't own a Goldwing...but if I did....I'd stash a pygmie in de trunk fer situations like dis.... Boomer....who sez offering dat pygmie a shot of tequila will have him popping dat trunk open in nothing flat.... I miss these BOOMERISMS..... I think BOOMER and PUC should go riding together... I just wanna tag along.... Link to comment Share on other sites More sharing options...
Neil86 Posted August 31, 2014 Share #11 Posted August 31, 2014 Another reason Yamaha is better. You need to use the key to lock the trunk. It is nearly impossible to lock the key in the trunk. If you are creative you can accomplish it. Jeff on the 1st gen its tough....2nd gen you can lock with key out. Link to comment Share on other sites More sharing options...
Condor Posted August 31, 2014 Share #12 Posted August 31, 2014 Jeff on the 1st gen its tough....2nd gen you can lock with key out. Gotta know how you can do it on a 2ndGen?? Then I can try it to see if it works.... Link to comment Share on other sites More sharing options...
Neil86 Posted August 31, 2014 Share #13 Posted August 31, 2014 Open trunk, turn to lock, remove key close trunk. Link to comment Share on other sites More sharing options...
Eck Posted August 31, 2014 Author Share #14 Posted August 31, 2014 And we learned this because??? Not what you think Bob, (this time anyway).... Just passing on tips and tricks for the GW owners. I too have a spare key on my wing for that just in case moment...In fact, I was cleaning it one day and found it. The previous owner put it there and never told me about it. However, being it is in a good place, I'm leaving it there. Link to comment Share on other sites More sharing options...
Condor Posted August 31, 2014 Share #15 Posted August 31, 2014 Open trunk, turn to lock, remove key close trunk. Do the keys have to be in it??? Link to comment Share on other sites More sharing options...
Neil86 Posted August 31, 2014 Share #16 Posted August 31, 2014 Condor... what I'm saying is with lid open you can set to lock then pull out key....if anyone closes the lid its locked. Link to comment Share on other sites More sharing options...
Condor Posted August 31, 2014 Share #17 Posted August 31, 2014 Condor... what I'm saying is with lid open you can set to lock then pull out key....if anyone closes the lid its locked. Why would anyone lock it before it's closed.... Link to comment Share on other sites More sharing options...
SilvrT Posted September 3, 2014 Share #18 Posted September 3, 2014 Why would anyone lock it before it's closed.... That should be obvious ... to see if they can lock their trunk with the ONLY key inside it.... Link to comment Share on other sites More sharing options...
Condor Posted September 3, 2014 Share #19 Posted September 3, 2014 That should be obvious ... to see if they can lock their trunk with the ONLY key inside it.... How many times do they have to do this to figure it out.... Link to comment Share on other sites More sharing options...
icebrrg3rd Posted September 3, 2014 Share #20 Posted September 3, 2014 Another reason Yamaha is better. You need to use the key to lock the trunk. It is nearly impossible to lock the key in the trunk. If you are creative you can accomplish it. On the MK1 you can, the lock has three positions, LOCK (lock mechanism can't move, you can't push the latch into it), SET (lock mechanism can move to allow trunk/saddlebags to latch), and OPEN. If you have it to SET and toss the keys in, the trunk or saddlebag can still latch shut and not be opened again w/o the key... -Andrew Link to comment Share on other sites More sharing options...
Barrycuda Posted September 3, 2014 Share #21 Posted September 3, 2014 My spare key is attached the the battery box, never an issue:twing: Interesting to know Michael, in case I need a quick ride to the store... Link to comment Share on other sites More sharing options...
Barrycuda Posted September 3, 2014 Share #22 Posted September 3, 2014 If you locked your key and remote keyless fob inside your trunk on a Honda Goldwing 1800, and you don’t have a spare key, here is a trick or a work around to help you out in this situation. This works like a charm but you will need two things. 1) -The allen wrench to take of the passenger grips off the seat so you can remove the seat. 2) - You will also need a 2ft long 14 / 16 gage wire for jumping the connection. Instructions: 1) remove seat 2) connect a wire to the "positive" on the battery terminal 3) under seat, find the GREY 14 pin connector - (on side without battery towards the back) 4) insert (just touch) the other end of the wire in the back of the connector to the "BLUE" wire 5) IT UNLOCKS note: Leave the GREY 14 pin connector CONNECTED - do not disconnect the connector as it needs to be connected to complete circuit. You should learn from this to ensure you carry or hide a spare key on your motorcycle just in case! Here is a photo of the GREY 14 PIN connector with instructions. Eck, you never cease to come up with more gems!! Thanks Link to comment Share on other sites More sharing options...
Barrycuda Posted September 3, 2014 Share #23 Posted September 3, 2014 Another reason Yamaha is better. You need to use the key to lock the trunk. It is nearly impossible to lock the key in the trunk. If you are creative you can accomplish it. Honda did drop the ball on that issue. To be fair, we do not have the cassette flap to tape the spare key to the inside.. However, I do like the individual locking and unlocking of individual bags, instead of just locking all or none... Link to comment Share on other sites More sharing options...
Barrycuda Posted September 3, 2014 Share #24 Posted September 3, 2014 And we learned this because??? Not what you think Bob, (this time anyway).... Just passing on tips and tricks for the GW owners. I too have a spare key on my wing for that just in case moment...In fact, I was cleaning it one day and found it. The previous owner put it there and never told me about it. However, being it is in a good place, I'm leaving it there. Care to PM the safe hiding spot?? Or any suggestions... Link to comment Share on other sites More sharing options...
Eck Posted September 3, 2014 Author Share #25 Posted September 3, 2014 Eck, you never cease to come up with more gems!! Barry, The actual article was found on another site, so I can not take credit for I am not the originator. I find it amazing how a this thread got turned around to a 1st gen trunk discussion though. Maybe we need a Goldwing tech section for nothing but tech articles all on its own, and only GW related articles discussion go in it. The 1st gen information posted in this thread is important and hopefully is not lost. It belongs in the 1st gen tech section for others to see. Link to comment Share on other sites More sharing options...
