fireman107a Posted August 5, 2014 Share #1 Posted August 5, 2014 I'm looking at a CT but need info on the correct size. I have a 2005 midnight venture with a rear tire of 155/90/15. Any good suggestions on what to use. Link to comment Share on other sites More sharing options...
mm482 Posted August 8, 2014 Share #2 Posted August 8, 2014 The 165/80/R15 is what most people run and some are running the TA Goodrich 155/80/R15. I plan to go with the TA 155/80/15 the next tire change. I want to lower the bike and raise the engine RPM a little. Earl Link to comment Share on other sites More sharing options...
revinger Posted August 8, 2014 Share #3 Posted August 8, 2014 I'm using the 155/80r15 Goodrich on my 2002 midnight also. Link to comment Share on other sites More sharing options...
wizard Posted August 8, 2014 Share #4 Posted August 8, 2014 I believe the Goodrich is a better built tire. I just had my 3rd mounted before this years traveling. Link to comment Share on other sites More sharing options...
mm482 Posted August 9, 2014 Share #5 Posted August 9, 2014 To those with the TA 155, did you see any difference in the engine performace with the smaller tire? Earl Link to comment Share on other sites More sharing options...
wizard Posted August 9, 2014 Share #6 Posted August 9, 2014 Not really. It did lower the rear a bit, so I lowered the front a bit. Link to comment Share on other sites More sharing options...
