User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 8 of 8
Thread: coolant
  1. #1
    Join Date
    Feb 2007
    Murrieta
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default coolant
    What coolant do we use in the venture, is this another motorcycle only coolant or can we use auto coolants
  2. #2
    Join Date
    Aug 2006
    Johnson City TN
    TN
    Post Thanks / Like
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    Default
    To me, any green coolant is probably good and they are all now designed for aluminum engines. I think I usually Prestone. I have always added distilled water with the antifreeze, but now they are pushing the 50/50 stuff.
    RandyA
    Ride as though you are invisible, not invincible.
  3. #3
    Join Date
    Nov 2007
    falling waters
    WV
    Post Thanks / Like
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Default
    Prestone 50/50 mix.
    [SIGPIC] Kevin Smith (Revks) If you waited until there is nothing else left to do but pray, you started praying too late.
  4. #4
    Join Date
    Mar 2007
    HERE AND THERE
    MI
    Post Thanks / Like
    Mentioned
    684 Post(s)
    Tagged
    0 Thread(s)
    Default
    Interesting topic, one of my 1st gens had obviously had non aluminum friendly anti-freeze used in it.. I found that out when I went to update the water pump impellar and noticed that the inside of water pump casing was majorly eaten away and globs of gelled goo came out.. I did ride that puppy out to its retirement but always wondered what the rest of the "hidden" aluminum coolant jackets looked like
    TIP AND PUC'S MILLION MILE VENTURE adVENTURE FOR OUR adVENTURES AND REPAIR ADVICE SEARCH YOUTUBE: PUC PUC AND TWEEKS
  5. #5
    Join Date
    Aug 2006
    Renton
    WA
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Default The Orange stuff
    I have always used the Orange Colored Stuff, and distilled water.
    Change every two years, so far, it always has looked pretty good
    at the Drain Out time !! So far, no problems.
  6. #6
    Join Date
    Sep 2008
    Stewartstown
    PA
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    I agree on the 50/50 coolant mix. I've changed coolant twice already and it sure is good to have that replaced on a regular interval.
    Keep On Riding!
  7. #7
    Join Date
    Aug 2006
    Arcade, NY
    NY
    Post Thanks / Like
    Mentioned
    66 Post(s)
    Tagged
    0 Thread(s)
    Default
    Just read the label and make sure the coolant is compatible with aluminum!!! For anti freeze, a 50/50 mix provides the lowest freezing temperature. Believe it or not, straight anti freeze will freeze at a somewhat higher temperature than a half and half mix. This is especially important for people in Minnesota...
  8. #8
    Join Date
    Aug 2006
    Shepherd
    TX
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    Any quality automotive green antifreeze will work in the Ventures. I always do as the others and mix it with distilled water. I dont buy the 50/50 as your really loosing money. I buy a gallon of 100% antifreeze, 1 gallon of distilled water and mix them to 50/50. Twice the product for just slightly over half the price...
    Gunboat....I eagerly await the day we can ride together again, Godspeed my brother
Similar Threads
  1. Oil in My Coolant
    By GaryZ in forum General Tech Talk
    Last Post: 02-19-2012, 10:05 PM
  2. Oil in Coolant
    By viking2seafarer in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 08-19-2011, 11:04 AM
  3. Coolant
    By truckin48 in forum General Tech Talk
    Last Post: 11-28-2010, 07:00 PM
  4. 2 Coolant ?
    By Sleeperhawk in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 05-14-2010, 03:07 AM
  5. What coolant to use?
    By rez in forum General Tech Talk
    Last Post: 08-23-2007, 11:07 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
