dingy Posted January 17, 2014 Share #1 Posted January 17, 2014 (edited) I am making heavy duty 4 gauge sets of 1st gen (83-93) battery cables. Included are three cables, positive battery to solenoid, solenoid to starter and negative battery to ground. 40 amp main fuse, ATC style with 2 fuses furnished (1 spare). Harness leads are 12 gauge wire. The harness terminals have the mating housing that will plug into the existing connectors on the harness. No soldering or cutting required. #4 gauge welding cable, 364 strand copper, EPDM insulation oil & flame resistant, black. -50 deg C to +105 deg C. Silver brazed barrel terminals, tinned electrolytic copper, 1/4" hole on main cables. All connections are crimped and soldered. Main cables are hydraulic crimped. Main cable connections are covered with flame retardant dual wall polyolefin heat shrink, mil spec rated. I could not locate boots for the 6 ring terminal ends. $50 a set includes priority shipping to US address. Other locations will be whatever postage increase costs. (Probably 1st class outside US.) I can add an extra un-fused 14 gauge 12 inch wire if desired to both battery terminals for $2 a set additional. Pictures of completed set attached. Pictures show additional 12 inch lead (optional). Last person that was going to do this was Snaggletooth last year. I have talked to him several times and he is no longer pursuing this. Gary Edited September 25, 2019 by Freebird Link to comment Share on other sites More sharing options...
Venturous Randy Posted January 17, 2014 Share #2 Posted January 17, 2014 This is a major upgrade for the 1st gen bikes. I recommend that anyone that has not done this make this a priority. With this mod and the starter ground mod, this will eliminate the vast majority of the start and especially hot start problems on these bikes. I appreciate what you do for this group. RandyA Link to comment Share on other sites More sharing options...
bendtdj Posted January 17, 2014 Share #3 Posted January 17, 2014 Dingy, I am definitely in for a set! Would you accept a personal check or postal money order for payment? Thanks for doing this. Dave Link to comment Share on other sites More sharing options...
dingy Posted January 17, 2014 Author Share #4 Posted January 17, 2014 Dingy, I am definitely in for a set! Would you accept a personal check or postal money order for payment? Thanks for doing this. Dave Check & Money orders fine. Paypal also. Will send you a PM with address. Gary Link to comment Share on other sites More sharing options...
Snaggletooth Posted January 17, 2014 Share #5 Posted January 17, 2014 Atta boy Gary. :thumbup: Glad you pulled that together. After changing my cables to 4ga. several years ago it didn't take much to understand how much of a major improvement the heavier cables made. They are the foundation for about every other upgrade to improve starting these old girls rather its a 4 brush starter, adding an AGM or doing Dano's starter engage mod. Don't matter if you don't do any other mods...... these are a great item to upgrade to. Glad to see they are going to be available again. :thumbup: From my Droid wherever I may happen to be at any given moment. Link to comment Share on other sites More sharing options...
Flyinfool Posted January 17, 2014 Share #6 Posted January 17, 2014 YES!!! Please:thumbsup: I need your PP address. Link to comment Share on other sites More sharing options...
dingy Posted January 18, 2014 Author Share #7 Posted January 18, 2014 I added pictures of completed cable set to 1st post in this thread. Pictures show optional extra 12" lead on both battery terminal connections. You probably only need these if you have installed extra fused accesories and would like an extra power feed for them. Gary Link to comment Share on other sites More sharing options...
313 Omer Posted January 22, 2014 Share #8 Posted January 22, 2014 I will take 1 if still available Link to comment Share on other sites More sharing options...
dingy Posted January 22, 2014 Author Share #9 Posted January 22, 2014 I will take 1 if still available PM sent with PayPal and mailing address is needed. Thanks, Gary Link to comment Share on other sites More sharing options...
frankd Posted January 22, 2014 Share #10 Posted January 22, 2014 Gary, The check's in the mail. Frank D. Link to comment Share on other sites More sharing options...
dingy Posted January 22, 2014 Author Share #11 Posted January 22, 2014 Gary, The check's in the mail. Frank D. So are the cables, should be there tomorrow. Gary Link to comment Share on other sites More sharing options...
frankd Posted January 24, 2014 Share #12 Posted January 24, 2014 The mail lady delivered my battery cables today, and when I opened up the box, I was impressed with the quality of the cables. Everything was well made, and welding cable was used for the battery cables. Welding cable is much more flexible than normal battery cable, which will ease installation. Good job Gary! Frank Link to comment Share on other sites More sharing options...
Goose68 Posted January 24, 2014 Share #13 Posted January 24, 2014 Please send me PP add I will take a set if you still have Link to comment Share on other sites More sharing options...
adventurer 08 Posted January 24, 2014 Share #14 Posted January 24, 2014 Gary, please put me down for one set with extra wire. PM me with your PP address. Link to comment Share on other sites More sharing options...
motorcycle.jockey Posted January 25, 2014 Share #15 Posted January 25, 2014 Are these going to still available in a month or two? I'm not quite ready right now Sent from my ASUS Transformer Pad TF700T using Tapatalk Link to comment Share on other sites More sharing options...
dingy Posted January 25, 2014 Author Share #16 Posted January 25, 2014 Are these going to still available in a month or two? I'm not quite ready right now Sent from my ASUS Transformer Pad TF700T using Tapatalk I might have them. I will mark a set for you and let you know when I am close to being out. I have sold almost half of what I got material for. Not saying I won't get more material though. Gary Link to comment Share on other sites More sharing options...
dingy Posted January 25, 2014 Author Share #17 Posted January 25, 2014 Please send me PP add I will take a set if you still have Gary, please put me down for one set with extra wire. PM me with your PP address. PM's sent. Thanks, Gary Link to comment Share on other sites More sharing options...
mralex714 Posted January 25, 2014 Share #18 Posted January 25, 2014 Put me down for one set with the extra wire. Link to comment Share on other sites More sharing options...
adventurer 08 Posted January 25, 2014 Share #19 Posted January 25, 2014 I ordered a set of cables from Gary this morning and he put them in the mail this afternoon, now that's some great service. HAPPY HAPPY HAPPY:):) Link to comment Share on other sites More sharing options...
rbig1 Posted January 26, 2014 Share #20 Posted January 26, 2014 gary I will take a set with extra wires. also do you have a thermostat housing for a 83 royal. pm me when you get a chance. for prices Link to comment Share on other sites More sharing options...
rbig1 Posted January 26, 2014 Share #21 Posted January 26, 2014 sent payment thanks dingy. extra wire and housing price included Link to comment Share on other sites More sharing options...
dingy Posted January 26, 2014 Author Share #22 Posted January 26, 2014 sent payment thanks dingy. extra wire and housing price included I will send them out tomorrow. Thank You, Gary Link to comment Share on other sites More sharing options...
mralex714 Posted January 29, 2014 Share #23 Posted January 29, 2014 Put me down for one set with the extra wire. What about me? Link to comment Share on other sites More sharing options...
dingy Posted January 29, 2014 Author Share #24 Posted January 29, 2014 PM sent. Thanks, Gary Link to comment Share on other sites More sharing options...
rbig1 Posted January 31, 2014 Share #25 Posted January 31, 2014 got my cables today. clean work. Link to comment Share on other sites More sharing options...
