User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 8 of 8
Thread: 1996 Yamaha Royal Star 1300 won't stay running
  1. #1
    Join Date
    Aug 2013
    Baraboo
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default 1996 Yamaha Royal Star 1300 won't stay running
    We were out riding and ran out of gas (reserve also). Put gas back in it and it started, then died... replaced the fuel filter- it still did the same thing. Checked all the lines, nothing appeared to be clogged. Thought maybe we burned out the fuel pump even though we could still hear it running. Read all of the posts on her and bypassed the pump and still won't stay running. The electrical problem indicator light keeps coming on... Acts like it's a fuel problem, but after going through and replacing everything, and trying all the tricks- the bike still won't stay running. Any of ideas on what to check next?
  2. #2
    Join Date
    Oct 2006
    Taylorsville, UT
    UT
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    Might want to pull the petcock and make sure the screens are not plugged.
    Dave
  3. #3
    Join Date
    May 2010
    Tichborne
    Canada
    ON
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Default
    2nd gens sometimes get a vacuum in the gas tank created by a plugged bypass or something like that. Someone else will better explain but next time it happens, try loosening your gas cap. If it sucks air when it opens, that's the issue.
  4. #4
    Join Date
    Aug 2013
    Baraboo
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Going to check the petcock again today just to confirm...but when you pull the line the gas runs right out of it at a full flow. Loosened the gas cap and it had no effect. When this initially happened it was pouring rain, the low fuel light came on and when heading up a large hill the bike started stuttering- switched to reserve and it ran about 100ft and quit. After towing it home, adding gas, it did start but only runs for about 30 seconds and quits- just like you hit the kill switch...
  5. #5
    Join Date
    May 2013
    Turkey Point Ontario
    Canada
    On
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default
    Plugged fuel filter? Is the fuel pump working?
  6. #6
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    70 Post(s)
    Tagged
    0 Thread(s)
    Default
    When you ran out of gas did you fill with fuel from a station?? Youi might have gotten a load of wet gas... Pull the line off the petcock again and drain some into a glass jar to check if you have water in your tank... If your getting flow thru the petcock I wouldn't suggest pulling to check the filters unless you'd want to check the stand pipe filters. DO you get the same flow thru the petcock in reserve and ON?? A plugged filter is also a good suggestion. There's all kinds of cr@p in the bottom of some tanks, and the reason it helps to run a bit of Sea Foam with every tank, and a good shot to a full tank every couple of months or so. It's also not a bad idea to drain the tank once in a while.
  7. #7
    Join Date
    Aug 2013
    Baraboo
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Engine indicator light comes on after bike has been running a good 2 min or so... then it shuts down like I hit the kill switch it.It will not restart. If I let it sit 2 minutes it will restart run 2 min light comes on and bike shuts down again. Any suggestions on what to check next?
  8. #8
    Join Date
    Aug 2013
    Baraboo
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Ground-Hugger View Post
    Fuel Filter was replaced and the pump is working...
    Quote Originally Posted by Condor View Post
    Got the same flow on "reserve" and "on"... the fuel filter was the first thing replaced... since I ran it out of gas- it lead me to believe it was fuel related- but everything with the fuel (lines, filters, pump) seems to check out. Possibly electrical? Again- it started and runs- then just shuts off. Talked to a mechanic that works on yamaha's and he had no other suggestions except for- "bring the bike in"
Similar Threads
  1. Replies: 25
    Last Post: 04-21-2013, 11:32 PM
  2. Gas tank for a 1996 Royal Star
    By flyfshn in forum Watering Hole
    Last Post: 03-06-2011, 02:46 PM
  3. FREE 1996 Yamaha Royal Star
    By scubarider in forum Watering Hole
    Last Post: 05-17-2009, 06:03 PM
  4. Short Exhaust for 1996 Royal Star
    By cableguy in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 04-12-2009, 11:19 PM
  5. Ape hangers on a 1996 royal star
    By olijobo in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 05-24-2008, 07:48 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
