gidzhome Posted April 28, 2013 Share #1 Posted April 28, 2013 anyone know the specs for valve clearance adjustments ? '03 RSV1300. Thanks,. Link to comment Share on other sites More sharing options...
etcswjoe Posted April 28, 2013 Share #2 Posted April 28, 2013 (edited) Take a look at this spread sheet: http://www.venturerider.org/forum/showthread.php?t=43411 Intake .11-.15 mm cold Exhaust .16-.20 mm cold Edited April 28, 2013 by etcswjoe Link to comment Share on other sites More sharing options...
Squidley Posted April 28, 2013 Share #3 Posted April 28, 2013 John, The intake clearances are 0.16 to 0.15 mm (0.004 to 0.006 in) Exhaust are 0.16 to 0.20 mm (0.006 to 0.008 in) Link to comment Share on other sites More sharing options...
RedRider Posted April 29, 2013 Share #4 Posted April 29, 2013 John, The intake clearances are 0.11 to 0.15 mm (0.004 to 0.006 in) Exhaust are 0.16 to 0.20 mm (0.006 to 0.008 in) Fixed the typo. RR Link to comment Share on other sites More sharing options...
steamer Posted April 30, 2013 Share #5 Posted April 30, 2013 do you replace the shim at the high measurement, .008 or the low measurement .006 Isn't it better to be loose, Higher number? Link to comment Share on other sites More sharing options...
etcswjoe Posted April 30, 2013 Share #6 Posted April 30, 2013 do you replace the shim at the high measurement, .008 or the low measurement .006 Isn't it better to be loose, Higher number? You want to adjust to the high end of the spec, however you may not have a choice depending on available shims. Link to comment Share on other sites More sharing options...
MiCarl Posted April 30, 2013 Share #7 Posted April 30, 2013 You can only buy shims in 0.05mm increments. What this means is there will be only one shim selection that will be in spec. Example: Your intake valve clearance is 0.11 mm with a 2.60 shim in it. The next thinner shim is 2.55 which will take the clearance to 0.16mm - too loose. Link to comment Share on other sites More sharing options...
