User Tag List
Thanks Thanks:  0
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: I have oil in my coolant!
  1. #1
    Join Date
    May 2010
    Ctown
    Australia
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I have oil in my coolant!
    I have oil in my coolant! I have read up on it here and apparently it could be as simple a fix as changing the plugs under the fins? Is this true? I am going to do the vmax cam upgrade and carburetor ugrade soon so I will have it pulled apart, should I check for any other problems that might be leading to the oil/water mix?
  2. #2
    Join Date
    Aug 2006
    Oberlin, OH
    OH
    Post Thanks / Like
    Mentioned
    209 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm sorry to say that I think you have misunderstood the information about the plugs. I don't think there is anyway that they can cause you to get oil in your coolant. Unfortunately, I think you have a much bigger problem. I'm not even sure that your Royal Star has those plugs, I don't know for sure but all the posts I've seen here about them has been in regards to the Royal Star Venture.
    Hopefully somebody else will come up with a simpler explanation but my first thought is a bad head gasket.
  3. #3
    Join Date
    Feb 2007
    Dixon Illinois
    Di
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    Freebird is correct, the plugs are just an external coolant leak concern, and have no way of causing your concern.
    Yours does have the same freeze plug style as the venture.
    You must have a head gasket failure to allow oil into your coolant.
    Mike
    YES I AM "THE DIAMOND CUT GUY"
    check out my site below
    WWW.THEDIAMONDCUTGUY.COM
    feel free to click on my e-mail below rather than pm please
    royalstarventure03@yahoo.com
  4. #4
    Join Date
    Jun 2010
    Pumpkintown(Pickens)
    SC
    Post Thanks / Like
    Mentioned
    39 Post(s)
    Tagged
    0 Thread(s)
    Default
    I may be way off base here, but couldn't the Breather (twinkie) cause oil and coolant to mix either from a failed gasket or an internal crack ? The only place in the manual that I could find that reference's the breather is on page 4-23
    Jay
    Patriot Guard Rider #18267
    '01 RSV......08 Hannigan RSV, 69' Buick GS 400 Conv.
    " Never ride faster than your angel can fly"
  5. #5
    Join Date
    Feb 2007
    Dixon Illinois
    Di
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by ragtop69gs View Post
    Remote, yet possible???
    Good call ragtop
  6. #6
    Join Date
    Jun 2010
    SC
    Post Thanks / Like
    Mentioned
    39 Post(s)
    Tagged
    0 Thread(s)
    Default
    Always best to start with the easy to get at things first.
    Jay
  7. #7
    Join Date
    May 2010
    Ctown
    Australia
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That sux. Ok so even if it is the Twinkie the gasket is more than likely faulty. If there is a crack would I be able to see it?
  8. #8
    Join Date
    May 2010
    Ctown
    Australia
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yeah I don't remember seeing the plugs under the fins either
  9. #9
    Join Date
    Jun 2010
    SC
    Post Thanks / Like
    Mentioned
    39 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by mbelik View Post
    Hard to say if it could be seen, if there is a crack, it may open under heat or pressure. There are methods for finding cracks that are not visible.
    Jay
  10. #10
    Join Date
    Nov 2008
    gulfport
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default oil in water
    My bet would be a head gasket.
  11. #11
    Join Date
    May 2010
    Ctown
    Australia
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ok well I will go with the gasket just ordered a set from thumpertalk. I will start pulling the bike apart today and get it ready. Means I probably won't get a ride until after Easter. I'm still waiting for a mate to make up the adapters for the 32 mm carbies so I guess I might need to give him a bit of push to get them done.
  12. #12
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Default This has happened before may not be serious
    I had this happen on by 98 Royal Star Tour Classic, and it turned out to be the seals on the water pump. There are a set of seals on the driven shaft that runs the pump, one side keeps coolant in and oil out, the other keeps oil in and coolant out. There is a chamber between the two that should stay dry, it has a small vent tube that you can check, if it is wet with either oil or coolant, that should tell you where the issue is.
    This is not the only place where coolant and oil could mix, but in my experience on this forum and others over the past 15 years this has been the most common cause.
    The fix is relatively easy and cheap, and you can buy a rebuild kit from Yamaha.
    I will tell you it is very difficult to get all of the oil out of the coolant system, it may take repeated flushes.
    Other wise do a compression test and leak down test to determine if you have a blown head gasket, very rare occurance on these motors.
    Steve K
    Edgewater , FL
    And the LORD said "Thou shalt have dominion over all of the animals, Except of course the cat."
    DR. Goldwing; has the antidote for the blues
  13. #13
    Join Date
    Jun 2010
    SC
    Post Thanks / Like
    Mentioned
    39 Post(s)
    Tagged
    0 Thread(s)
    Default
    Steve, That sounds like a better possibility of the cause. I do recall reading about what you are saying. That or a head gasket are more likely than what I suggested.
    Jay
  14. #14
    Join Date
    Feb 2012
    LYON in FRANCE
    France
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hello,
    If there is no bubbling in the reservoir, then this is the water pump seal.
    Chris
  15. #15
    Join Date
    Aug 2006
    Apple Valley
    MN
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Do you have coolant fluid in your oil?
    . "A hundred questions go unanswered. A thousand answers go unquestioned"
    [B[SIZE=5]]"The difference between genius and stupidity is the genius has limitations" [/SIZE][/B]
Similar Threads
  1. coolant getting to the oil
    By OrlinEngh in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 09-16-2012, 09:37 AM
  2. Oil in My Coolant
    By GaryZ in forum General Tech Talk
    Last Post: 02-19-2012, 10:05 PM
  3. Oil in coolant
    By BigBear in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 05-09-2011, 02:38 PM
  4. 2 Coolant ?
    By Sleeperhawk in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 05-14-2010, 03:07 AM
  5. What coolant to use?
    By rez in forum General Tech Talk
    Last Post: 08-23-2007, 11:07 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
